*..Fasten seatbelt light?..*
I had a mechanic fix my heater valve on my heater. When I got it back every once in awhile while I'm driving my fasten seatbelt light will come on for about 10 secs and then go off. I talked to my mechanic and he said he didn't touch anything that would effect that. What might cause this issue? Thanks for the help :)
Ken
What year and model is your soob? I can only speak for the old ones.
On older cars in general, there's a switch in the buckle, two wires that run down under the carpet under the seat, there's a connector there, I'd check that first... If it's got automatic seatbelts that slide along the top of the window, that might be a little more difficult to check...
I'd pull the bulb in the instrument cluster, but I'm a cheapskate... and also a fan of common sense... my thinking is do you really need a light to remind you to buckle up... like you're not going to notice a big double strap across your body? :D just my 2 cents tho.
