NWSubie Posted June 29, 2012 Share Posted June 29, 2012 So I am doing an ej swap and I will not be having power steering or ac so I would like to find a serpentine belt that will only run the crank pulley and the alternator. Anyone know where to fine this belt napa just said "we dont sell them" and went on helping another customer so I'm hoping to find a part number that I can order offline. Thanks. Link to comment Share on other sites More sharing options...
ocei77 Posted June 29, 2012 Share Posted June 29, 2012 You are asking a lot from a busy counter person, for a size that is not known. Since our belts are designed to go around the PS pulley, you have to measure around both pulleys with a flexible tape and get a belt a little larger so you can get it over the pulleys and still be able to tension it. Don't be surprised if your first try is not successful and they won't accept a return. Go to a Gates or other belt mfg site and try to narrow size down. O. Link to comment Share on other sites More sharing options...
porcupine73 Posted June 29, 2012 Share Posted June 29, 2012 It sounds like if you measure it like that even using a piece of string or dental floss that should get you plenty close. That alt seems to have quite a bit of adjustment in it for the belt tension. Link to comment Share on other sites More sharing options...
puhi Posted June 29, 2012 Share Posted June 29, 2012 http://www.ausubaru.com/forum/showthread.php?t=14676 Link to comment Share on other sites More sharing options...
NWSubie Posted July 4, 2012 Author Share Posted July 4, 2012 Thanks for the info and the link Ill be ordering that belt and hope it works. Link to comment Share on other sites More sharing options...
