UMT Posted July 1, 2012 Share Posted July 1, 2012 Ok, having 'check engine' lite on constantly and have narrowed it down to O2 Sensor. 99 Impreza Outback with J223 engine. I found the one in front of the catalytic convertor but, for the life of me, can't find the other. Isn't this supposed to have 2 O2 sensors? I looked at the back of the converter and if it's there, it's very well hidden. What's up with this, guys? Thanks, UMT Link to comment Share on other sites More sharing options...
ocei77 Posted July 1, 2012 Share Posted July 1, 2012 Further down the line after 2nd cat. Tucked up. Easier visible from driver's side. The connector is well wrapped in protective stuff. O. Link to comment Share on other sites More sharing options...
UMT Posted July 1, 2012 Author Share Posted July 1, 2012 I read the board quite a bit and I've heard that it is usually only necessary to replace the front one????? Did I get this wrong? UMT Link to comment Share on other sites More sharing options...
UMT Posted July 1, 2012 Author Share Posted July 1, 2012 OK, I found it. Looks like I was looking at the 2nd one. Which one is usually the problem, front or back? These things are a PIA, by the way. I did purchase a 3/8 special socket to remove them from Harbor Freight (beings that I don't plan on making a living doing this) for 4.99, and it works great. Well built and the 3/8 one has an offset which makes things easier. (In my case anyway) Link to comment Share on other sites More sharing options...
brus brother Posted July 1, 2012 Share Posted July 1, 2012 Local Autozone lets you borrow the 2 types of wrenches for O2 sensors. Link to comment Share on other sites More sharing options...
Fairtax4me Posted July 1, 2012 Share Posted July 1, 2012 OK, I found it. Looks like I was looking at the 2nd one. Which one is usually the problem, front or back? Depends on the problem. What's the problem? Link to comment Share on other sites More sharing options...
UMT Posted July 1, 2012 Author Share Posted July 1, 2012 (edited) Local Autozone lets you borrow the 2 types of wrenches for O2 sensors. Yeah, I knew that. The problem is that I live a good 60 miles from the nearest Autozone. I only spent 4.99 for the socket. Cheaper than gas, etc... Thanks. Edited July 1, 2012 by UMT Link to comment Share on other sites More sharing options...
UMT Posted July 1, 2012 Author Share Posted July 1, 2012 Depends on the problem. What's the problem? Just that the 'check engine' light came on some time ago. Had a code reader put on it and got the code for bad PCV/O2 sensor. Installed new PCV and engine light still on. Doesn't seem to affect gas mileage and I have 200K on the car, so I haven't been too concerned about it. Had some time to look into it but as I said, I've read different opinions about which one is usually the culprit on the forum. Car runs like a top but that light is starting to annoy me! Ha., UMT Link to comment Share on other sites More sharing options...
Fairtax4me Posted July 1, 2012 Share Posted July 1, 2012 There is no code for the PCV system. Post the exact code please, otherwise there's no way to give accurate information. Link to comment Share on other sites More sharing options...
UMT Posted July 1, 2012 Author Share Posted July 1, 2012 There is no code for the PCV system. Post the exact code please, otherwise there's no way to give accurate information. Shoot! I forgot the code! Guy just said it was either PCV or O2 Sensor as it was 'running rich.' Thanks for the help, I'll try to get it again. Link to comment Share on other sites More sharing options...
