Subaru Lingo. EJ22, EJ25, EA81-82 ?
a quick and no doubt limited run down:
EA engines are old school Subarus: XT, GL's, Loyale's, RX, Brats, all the old school Subaru's. 70's - early 90's stuff.
EJ engines are found in Impreza, Legacy, Forester, Baja. from 1990 - roughly current.
ER27 and EG33 are one model engines for the XT6 and SVX. The ER27 is very similar to EA engines - same pistons, valves, etc, just two more cylinders.
the numbers following the letters are the size of the motor. EJ22 is a 2.2 liter, etc.
EZ are the 6 cylinder motors used in 2001+ Subaru Outbacks and Tribecas.
also, EA
EA-71 1.6l OHV
EA-81 1.8l OHV
EA-82 1.8l SOHC (cams on top of heads)
FBXX NEW engines with XX being engine code(new impreza, forester, BRZ etc.)
On the older stuff, a "T" added to the end is turbo
A sticky with acronyms common to this board would be really good for new readers. There are many, some subaru specific, some not. For example:
NA= naturally aspirated (as in not turbocharged)
5MT = five speed manual transmission
4EAT = four speed automatic transmission
SPFI = single point fuel injection
MPFI = multi point fuel injection
SOHC =single overhead cam
DOHC = dual overhead cam
Some I remain confused about:
EJ25D - first edition EJ25 with DOHC?
EJ251 - first edition EJ25 with SOHC?
EJ252 - second edition EJ25 with SOHC?
EJ253 - third edition EJ25 with SOHC?
