car is vibrating while accelerating ??? not tires
Ok so my girl has a 2000 2.5l outback 239,000 + miles , about a week ago the car started to vibrate while accelerating . The harder you push on the accelerator the worse the vibrations( although when u let off the accelerator the vibrations go away ) , feels almost as if a tire is split but had them checked out, balance is ok to . A local mechanic thinks it maybe the transfer case or torque converter any suggestions on how to diagnose this problem ? ... there are no subrau dealers close
ok i have had the tire rotated balanced and checked for splits all that is ok. The mechanic did say that there was a little warp on the driver side front axle but he said that should not cause this bad of a vibration ....... now that being said i just remembered back in may we pulled a code from the car ( check engine light came on ) and it was for a torque converter locking up could all this be related ?????
Typical symptom for a bad DOJ (inner joint on the axle) is vibration during acceleration which instantly goes away when you let off on the gas. Sometimes the vibration is just barely noticeable and others I've seen it so bad that it feels like the transmission is about to fall out! How many miles on the car and did you recently install a replacement axle?
Re-read your original post. 239K on the car! If that's the original axle, that's the problem. My experience has always been with the manual transmission so I don't know if the torque convertor might be an issue. I also have always had this issue on the drivers side; probably since that's right above the catalytic convertor so the boot fails there more often than the passenger side.
Edited by edrach
What did he mean by a "little warp" on the front axle? If it's related to the DOJ then the axle is your issue.
thanks Ed i will take it to my mechanic on monday hopefully it is the DOJ otherwise i am told it may cost a couple of grand to fix ... will let you know the out come
CHEERS all for the help ....... will keep you posted
CVJ is the outer joint; inner joint is DOJ.
I know this, I just said the axle in general, and then specified the inner.
I agree if it's the original axle, it's probably the cause. They can look just fine, and "feel" just fine when you grab and try to move it by hand, but can cause vibration when driving. Just because it looks ok, doesn't mean it is.
same thing on my older GL. Inner DOJ on the axle. a little warped axle could be that one of the parts of he DOJ have failed and left it offset and will transmit directly to the hub a hellacious vibration under throttle.
Never seen a BAD subaru torque converter, much less one that causes vibration. Sounds like you need to find a more subaru specific mechanic.
Nothing to do with the torque converter.
That would vibrate with engine speed, not wheel speed, and would not change when taking your foot off the gas.
This is drivetrain related. Bad U joint, bad inner CV axle, bad carrier bearing or carrier bushing.
Have you tried adding the AWD fuse? That puts the car into FWD and stops sending power through the rear driveshaft. IF the vibration is still there with the fuse in, then you know to check the front. Sometimes, it's useful to swap the front cv shafts, side to side. If the problem moves to the opposite side, then you have your answer. If it doesn't make any difference, then you may gain more life from the cv's anyway, as they are now driving on the less worn faces of the cv joints.
no i have not tried the AWD fuse ........... should i remove it ? not sure about all this ............ what i do know is that the vibrations are at there worse when i gun the accelerator and a lot less when i slowly accelerate ( but can still feel it ) and the vibrations is coming from the front end ............. very baffling, i have been told by the mechanic maybe drive train , torque converter , transmission , axel , or transfer case ............. not wanting to replace all of this if i don't have to .................... ok everyone what should i check 1st second and so on ......
again i appreciate all the help
Only use OEM axles or you will probably be fighting the same vibration. With cheap remanufactured axles and new aftermarket axles, the tolerances within the inner joint can vary from being too tight to too loose. Both of which can cause vibrations while accelerating and decelerating.
I've replaced quite a few aftermarket axles with rebooted OEM used axles and had good results too as long as they weren't making noise. That is also a cheaper option. Boot kits are fairly inexpensive and not too terrible to do. Just be ready for a greasy mess:brow:
  • 1 month later...
Tie rod end? Ball joint? Transmission bushing?
Is it a vibration, or a knocking?
Were the wheel bearings checked?
When you speed up does it speed up with the speed of the wheels or about 4 times as fast?
The axle could be shot and seem tight when the car is up on the lift.
Make sure it gets checked with the weight on the wheels.
i have had the tie rods , axle , drive train , tires changed and balanced , the vibration is more pronounced when the car is going up hill and yes when u speed up the vibration increases but again when u go up hill it feels as if the car is going to shake apart ............. like something is out of balance bad
stop driveing and check the front ujoint in the driveshaft had one break and smash the whole tailshaft of trans and had one two days later same thing and one a week before same all the front ujoint makes it vibrate like crazy will feel like its in the floor under you bum or in back end of car ushaly has a ping when put in gear or transitioing from drive to reverse check all ujoints
