The FNG Posted July 10, 2012 Share Posted July 10, 2012 I have an EA82 SPFI head I need to remove the lifters from. How are they held in the head and what is the best way to get them out? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 10, 2012 Share Posted July 10, 2012 They aren't held in at all. They should just fall out. If they don't then there's a ridge holding them in place. Which likely means the head is garbage due to lifter bucket wear and so are the lifters so throw the whole mess in the scrap metal bin. GD Link to comment Share on other sites More sharing options...
idosubaru Posted July 10, 2012 Share Posted July 10, 2012 i've never had a problem reusing them but i never really looked into why they were stuck there. i would just drop them off at a machine shop and they'd give them back with the HLA's removed after resurfacing the heads. have no idea how they got them out. soak them in penetrant? Link to comment Share on other sites More sharing options...
The FNG Posted July 11, 2012 Author Share Posted July 11, 2012 I was able to pull one out. It seems like all the lifters are good, they never ticked and they all spin freely in place. Anybody have ideas??? I need to get these out because I really don't want to buy new ones. Link to comment Share on other sites More sharing options...
86 Wonder Wedge Posted July 11, 2012 Share Posted July 11, 2012 It's not the best method, but there are small oil relief holes next to the HLA buckets. If you have an air compressor, I've had luck using a small nozzle air gun and back-feeding them to get them to pop... however, I've also had to destroy several using pry bars and needle nose since they WOULD NOT LIFT. Spin and wiggle, yes. But WOULD NOT lift up. Sealed Power STILL has them available from most auto parts houses (Advance, NAPA, Oreilly) or RockAuto I'm sure can get them if you end up destroying one or several. Good luck! Link to comment Share on other sites More sharing options...
idosubaru Posted July 11, 2012 Share Posted July 11, 2012 mizpah engineering also has them for like $6 each rebuilt. http://www.mizpahprecision.com/pricing.htm Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 11, 2012 Share Posted July 11, 2012 mizpah engineering also has them for like $6 each rebuilt. http://www.mizpahprecision.com/pricing.htm They don't have any in stock though - you must send them your set and wait for them to rebuild them. They don't have a stock of EA82/ER27 lifters unfortunately. GD Link to comment Share on other sites More sharing options...
tractor pole Posted July 11, 2012 Share Posted July 11, 2012 mizpah engineering also has them for like $6 each rebuilt. http://www.mizpahprecision.com/pricing.htm I sent a set and I had them back in about a week from the time I sent them. about $55 shipped for a set of 8. Ben Link to comment Share on other sites More sharing options...
The FNG Posted July 12, 2012 Author Share Posted July 12, 2012 I've heard about them, but if they don't have any in stock, then it doesn't really help me unless I can send them the entire head as my cores since the lifters are stuck. But as far as getting them out, it sounds like the pull and pray method is what most do??? I haven't had too much luck with that in the past... Link to comment Share on other sites More sharing options...
Petersubaru Posted July 12, 2012 Share Posted July 12, 2012 I've heard about them, but if they don't have any in stock, then it doesn't really help me unless I can send them the entire head as my cores since the lifters are stuck. But as far as getting them out, it sounds like the pull and pray method is what most do??? I haven't had too much luck with that in the past......maybe these lifters have a ridge and are stuck in there, or are your lifters covered in a brown oily sludge that can act like glue..dribble a little gas over them.... Link to comment Share on other sites More sharing options...
Quidam Posted July 13, 2012 Share Posted July 13, 2012 ...maybe these lifters have a ridge and are stuck in there, or are your lifters covered in a brown oily sludge that can act like glue..dribble a little gas over them.... Ha, I was thinking using gasoline too:) I've never seen any stuck ones before though. Sounds like varnish possibly? Anyway, I cleaned some stuff a couple weeks ago using regular gas from a Marathon station. It disolves varnish I discovered, and I used gloves because it causes burning of the skin near instant. I thought next time I pull some varnished wrist pins that's what I'd try. PB Blaster won't disolve that stuff, but I'm pretty sure that gasoline will. Doug Link to comment Share on other sites More sharing options...
The FNG Posted July 13, 2012 Author Share Posted July 13, 2012 The one I pulled out had absolutely no varnish on it and I am expecting the same for the others. I think there is a little lip on the steel sleeve they sit in and that is what they are held up on. I will try compressed air, but I have little hope for that. I am scrapping the head, so would there be an issue with grinding down the sleeve? Link to comment Share on other sites More sharing options...
Quidam Posted July 13, 2012 Share Posted July 13, 2012 I suppose it's possible that the bushing gets forced up to the point of expanding over the ring on the lifter. That snap ring is there to limit the travel of the bushing...cut away huh? Doug Link to comment Share on other sites More sharing options...
The FNG Posted July 13, 2012 Author Share Posted July 13, 2012 Just an idea, maybe not a good one though. Link to comment Share on other sites More sharing options...
