1986 2wd 3door coupe leveling question
Hey all,
So, Ive been doing some searching on leveling out the
front of my car with the back (front sits about 2 inches higher than back).
From what I have read it looks like I just need front 2wd xt struts and springs and I should be good to go.
Just seeking confirmation on if this is correct or not before I get into the project...Also, just wondering if
the xt strut/spring combo is a direct bolt on or not and what year(s) will work.
Thanks in advance,
Chris
PS. Here is a couple of pics to show the current ride height...
If your Subie is 2WD, you can use the 4WD version of the Shock absorbers, because those has the Base for the Coil Spring, welded Two inches Up on the Shock's Body, so they will Lift your ride a Li'l bit.
If your Subie is 4WD, you can also use the Coil Springs from the Front of a 1992 Honda Accord in the Rear of the Subie.
More info: ~► Here.
Kind Regards.
  Quote
More info: ~► Here.
Kind Regards.
First of all, thank you for the reply...
...so, I think I will try to find me some 4wd rear shock absorbers
to throw in there with the 2wd springs and I will also check out the Toyota
KYB absorbers at work to see what price i can get em to :D
  Caboobaroo said:
4wd rear shocks are quite different in length compared to the 2wd. I would try to replace the rear springs with 4wd ones first. Should get the butt up in the air for ya:headbang:
Cool, I will give that a try first... Thank you for the reply :D
  • 6 months later...
My coupe has the same issue, back end is sagging, needs new shocks.
I was thinking of leaving it like that and lowering the front to match, but the ride is too rough, bottoms out on speed bumps with anything loaded in the back.
So I'll be getting new shocks.
