cohophysh Posted July 15, 2012 Share Posted July 15, 2012 Ugh.....another problem, this is getting old. 90 leg 2.2 manual 364K miles. so here is the issue, when stopped the car idles between 100rpm-900rpms. Up and down up and down. At one point it did die but started back up. No CEL I have recently replaced Knock sensor, fuel filter, plugs, wires, and PCV. Any thoughts... Link to comment Share on other sites More sharing options...
cohophysh Posted July 16, 2012 Author Share Posted July 16, 2012 So if it is the IACV, how do you clean it? Link to comment Share on other sites More sharing options...
mikaleda Posted July 16, 2012 Share Posted July 16, 2012 oxygen sensor Link to comment Share on other sites More sharing options...
DustyWolfe Posted July 18, 2012 Share Posted July 18, 2012 throttle position sensor Link to comment Share on other sites More sharing options...
cohophysh Posted July 18, 2012 Author Share Posted July 18, 2012 DustyWolfe said: throttle position sensor ya that is my next thought, but what to do, replace, adjust? Link to comment Share on other sites More sharing options...
mikaleda Posted July 18, 2012 Share Posted July 18, 2012 try adjusting first if that doesn't fix it than replace with one from a junk yard its like ten bucks. don't buy one new they are over $300 i just priced one. idle problems are usually oxygen sensors from my experience but it wouldn't hurt to try and adjust your tps. Link to comment Share on other sites More sharing options...
davebugs Posted July 18, 2012 Share Posted July 18, 2012 I'm electrically challanged. So I swap the whole throttle body rather than the sensor. Link to comment Share on other sites More sharing options...
wtdash Posted July 18, 2012 Share Posted July 18, 2012 (edited) cohophysh said: Ugh.....another problem, this is getting old. 90 leg 2.2 manual 364K miles. That is some impressive mileage...I'd be feeling my age @ 364K miles/22 years old too. +1 on just replacing the whole TB. Does it idle poorly when started cold - after sitting overnight? If so, it's not the 02 sensor, IMHO, as I've read they don't do anything 'til the car is in closed-loop and @ operating temp. 1. I'd clean out the IAC - don't use WD-40 or something that will leave a residue. I think brake cleaner is best? POST on cleaning. 2. Also, clean the MAF sensor w/MAF-specific cleaner. 3. Coolant sensor, aka CTS - if it's giving faulty readings everything else the ECU controls will be messed up. Does it start OK when cold or crank more than usual? 4. O2 sensor 5. ECU could be bad...but unlikely. 6. Fuel pump GL, Td Edited July 18, 2012 by wtdash Link to comment Share on other sites More sharing options...
cohophysh Posted July 18, 2012 Author Share Posted July 18, 2012 ya she has put in the miles...here is another tid bit, it only idles like this once the engine has reached operating temperature. Link to comment Share on other sites More sharing options...
