tgrey Posted July 18, 2012 Share Posted July 18, 2012 I have been told that the problem is in the ignition tumbler assembly and that a new cylinder and key will fix the problem...trouble is I can't find one anywhere!!! Advance Auto, O'Reily's, Napa all didn't have one...can't find one on line...I don't think I need the whole switch...all the acc's work, switch makes engine fire up...but key will not turn when all the way back in "OFF" position...key is very very worn...after jiggling the key it will turn...can somebody tell me where I can find one...dealer??? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted July 19, 2012 Share Posted July 19, 2012 try here: http://www.car-part.com . Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted July 19, 2012 Share Posted July 19, 2012 It's probably a very infrequently needed part so I doubt there would be much in the aftermarket for it. Used sourced through car-part.com as mentioned or take a look here looks to be about $150. Quote Link to comment Share on other sites More sharing options...
ocei77 Posted July 19, 2012 Share Posted July 19, 2012 You can try reverse tracking. Go to : http://opposedforces.com/parts/legacy/ See what years use the same part number and then search salvage parts. O. Quote Link to comment Share on other sites More sharing options...
nipper Posted July 19, 2012 Share Posted July 19, 2012 I'm not sure of the issue as SMP (Standard Motor Products) has them all over ebay. Quote Link to comment Share on other sites More sharing options...
