presslab Posted July 25, 2012 Share Posted July 25, 2012 I'm going to put a 4EAT into my Vanagon. It already has an EJ25 engine, so with the 4EAT no adapter plate is needed. I plan to use a 4.44:1 R&P. The gearing with this should be pretty close to ideal I hope, and I think with the EJ25 I'll be able to hold 65 MPH in 4th (around 2600 RPM) with the torque converter locked up. To reverse the R&P direction (as the Vanagon is rear engined) I plan to replace the reduction gearset with a chain. I'm currently investigating chains that will work, although it's hard to find real spec's. Currently the top contender is the Morse Hy-Vo chain which is used in a lot of 4WD transfer cases. However the widest chain I can easily fit would be 1", and I'm unsure if this can handle the power. The Jeep YJ transfer case chain is 1" (to drive the front wheels) so maybe 1" will be sufficient. A few things I'll need to figure out is how to mount the new sprockets to the old shafts. I'm considering machining (or wire EDM) the old gears into hubs, and then shrink fit and weld the new sprockets on. I'm unsure if I'll need to re-heat treat the sprocket teeth, but I'll check the hardness after the welding. The bearing structure and the parking pawl system complicate things here, but I think this is doable. Any ideas about chains or fabricating sprockets would be great! Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 25, 2012 Share Posted July 25, 2012 (edited) Wouldn't the R&P still be driving in reverse all the time? The gears really weren't designed to do that - you would be running on the coasting side of the diff gears which is significantly weaker and in a vehicle that's a lot heavier.... The front diff on my t-case lifted hatch is an R-160 that's been turned around and used in the front. It ate itself once and had to be replaced already. R&P chewed up pretty good and that one isn't even used to drive the car except when 4WD is engaged. I wouldn't expect it to last very long in that scenario. All the transaxle conversions I've seen have swapped the R&P for a reverse drive set that has the proper cut and/or flips the ring to the other side of the pinion. GD Edited July 25, 2012 by GeneralDisorder Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted July 25, 2012 Share Posted July 25, 2012 just thinking about harley/big v-twin chains and belts. don't some experimental aircraft use chain reduction for the props? sounds like a wild project! Link to comment Share on other sites More sharing options...
presslab Posted July 25, 2012 Author Share Posted July 25, 2012 I've read that the R&P in the 4EAT already uses the "coast" side of the R&P gears for "drive", so maybe it will make it slightly stronger to reverse it? I need to check this out. There is no reverse R&P set available for the 4EAT that I know of. I even have a spare 5MT in the shed but I've decided on the 4EAT. Smallcar has mentioned working on a reversed chain drive, and the guy in Australia is working on something too, but there is nothing available now and no ETA. A belt isn't strong enough, but yes I have seen aircraft that use the Hy-Vo chains. Here is an aircraft gear maker mentioning the issues with Hy-Vo chains, but still says they are a viable solution. http://www.epi-eng.com/propeller_reduction_technology/chain_drive_issues.htm Link to comment Share on other sites More sharing options...
presslab Posted July 31, 2012 Author Share Posted July 31, 2012 Here's an intermediate shaft from a FWD. You can see the width available between the bearings for a chain. If I wanted a wider chain I could make a longer intermediate shaft (and cover spacer), but that's more $$$. Link to comment Share on other sites More sharing options...
presslab Posted July 31, 2012 Author Share Posted July 31, 2012 I have another thought as well. What about making an external input shaft to the pinion gear? This would allow an external t-case with two driveshafts between the tranny and the t-case. The t-case will drive the pinion with an internal chain, along with the possibility for low range and 4WD to the front. I know the t-cased lifted Subies use a front diff under the existing one, right? But being able to utilize the existing diff inside the 4EAT would open up some possibilities. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted July 31, 2012 Share Posted July 31, 2012 maybe re-work the inside of those old gear-hub reducers from the 70s to reverse direction at the wheel? problem is, probably not a good ratio for driving on the road. Link to comment Share on other sites More sharing options...
nipper Posted July 31, 2012 Share Posted July 31, 2012 I have read of somone flipping te diff on a sooby, google it should come up. Link to comment Share on other sites More sharing options...
nipper Posted August 1, 2012 Share Posted August 1, 2012 http://www.subarugears.com/ Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted August 1, 2012 Share Posted August 1, 2012 http://www.subarugears.com/ winner! Link to comment Share on other sites More sharing options...
presslab Posted August 1, 2012 Author Share Posted August 1, 2012 The fine print: We do NOT manufacture ring and pinions for the 6 speed STi transmissions or Automatic transmissions. Link to comment Share on other sites More sharing options...
nipper Posted August 1, 2012 Share Posted August 1, 2012 Sometimes then you have to compromise your design. If you check the 6 speed there most likely isnt that much of a difference for your application. More gears are used for better mpg, not necassarilly driveability. Link to comment Share on other sites More sharing options...
LPGsuperchargedBrumby Posted March 12, 2013 Share Posted March 12, 2013 can you not do flip the diff over like is done on manual subaru transmissions for use in beetles and kombi's? Like this 1 Link to comment Share on other sites More sharing options...
ivans imports Posted March 12, 2013 Share Posted March 12, 2013 sweet the 73 super bettle gets a 2.5 twinn cam turbo with a 4eat with high stall waiting to see a reverse crown and pinion kitt Link to comment Share on other sites More sharing options...
Gloyale Posted March 15, 2013 Share Posted March 15, 2013 can you not do flip the diff over like is done on manual subaru transmissions for use in beetles and kombi's? Like this 4eat ring gear rides to the far right side, pinion shaft off center. Hmmmmm..... Perhaps a 5spd diff carrier, with the centerd ring could be mounted with the ring to the other side???? I doubt it would work but hey. At least worth a look. Link to comment Share on other sites More sharing options...
Gloyale Posted March 15, 2013 Share Posted March 15, 2013 can you not do flip the diff over like is done on manual subaru transmissions for use in beetles and kombi's? Like this Link to comment Share on other sites More sharing options...
WoodsWagon Posted March 23, 2013 Share Posted March 23, 2013 (edited) maybe re-work the inside of those old gear-hub reducers from the 70s to reverse direction at the wheel? problem is, probably not a good ratio for driving on the road. The gear hub reduction boxes would work well, but they were all swing axle design on the US models, so the transmission is the pivot point of the rear suspension. Brazilian bus's used an IRS reduction box that had a U joint half shaft running to it. Here's a swingaxle one with a CV axle modified to fit: http://www.mudtrials.org/thetrialscar41.htm The gear reduction on the later ones was 1.26:1 Combine that with the steep overdrive of 0.69 in a 4eat with an avalable 3.9 final drive and you end up with 2700 rpms at 65mph on 205/75r15 tires which should be close to a stock bus size. That's a livable cruising RPM. Edit: Looked up stock bay window bus tires. They are 185/80r14's which puts 65mph at 2900 rpms. Still OK for highway use especially as that's what a stock 2003 Outback 5spd is turning at the same speed. Edited March 23, 2013 by WoodsWagon Link to comment Share on other sites More sharing options...
apintonut Posted July 22, 2013 Share Posted July 22, 2013 sounds like u are on the right path and im sure the 1" chain will last quit well big block v8 use the chain on the timing chain that are very small and last long time and lots of rpm's and torque Link to comment Share on other sites More sharing options...
ivans imports Posted July 23, 2013 Share Posted July 23, 2013 I did a realy hard reverse run in the buggy and it smoked the back side of pinion teeth not ment to drive hard backwards eats the teeth Link to comment Share on other sites More sharing options...
apintonut Posted August 15, 2013 Share Posted August 15, 2013 (edited) ok this its been done and works good. i may be able to get one for you but the chain makes a little noise so was never put into production . how ever there is a new design may be works Edited August 15, 2013 by apintonut Link to comment Share on other sites More sharing options...
ivans imports Posted August 15, 2013 Share Posted August 15, 2013 put a ilder bering on the chain Link to comment Share on other sites More sharing options...
Yota-toy Posted June 2, 2015 Share Posted June 2, 2015 I am interested in an update from this thread. Has the mod been completed/tested? I just bought a Westy and will be purchasing my donor SVX this weekend and would love to do the 4EAT swap. Tkx Link to comment Share on other sites More sharing options...
cbas2001 Posted May 24, 2017 Share Posted May 24, 2017 Hi, I'm looking for exactly the same solution, but I think this topic died ... At least I wanted to be the only one in the world with rear engine and automatic .. haha Link to comment Share on other sites More sharing options...
Crazyeights Posted May 25, 2017 Share Posted May 25, 2017 What about the chain drive setup used in older GM FWD automatics, would that be of any help? I have no idea how big they are but they last an age if cared for. Link to comment Share on other sites More sharing options...
Subaru Scott Posted May 25, 2017 Share Posted May 25, 2017 I love to see people thinking outside the box, and doing cool swaps with Suby engines and trannies. But in this case, it just will not work unless you can come up with a reverse ring and pinion. That means you, or someone else has to make one. There is no other way around it. If you try to drive the standard rotation gears backwards, they will die. Simple as that. Link to comment Share on other sites More sharing options...
