rdweninger Posted July 27, 2012 Share Posted July 27, 2012 Well... it's time to change the rear diff fluid. '85 EA82 4WD 5mt Wagon. I searched the archives... but exactly how and where will the rear diff be marked if it is an LSD? I just bought 80w90 but got to thinking "what if I have the limited slip?" Does anyone know the location of the marks and what they look like? Thanks for the help. I appreciate it. Ron W. Link to comment Share on other sites More sharing options...
bratman18 Posted July 27, 2012 Share Posted July 27, 2012 Chances are unless it's a turbo, it's not an LSD. You can check by jacking up and spinning one wheel. If it's an LSD then both rear tires will spin in the same direction. If it's not, they will spin opposite. Link to comment Share on other sites More sharing options...
WoodsWagon Posted July 27, 2012 Share Posted July 27, 2012 Most probably not, but if it is it has a big silver sticker on the rear cover that will have LSD in big letters as well as the 3.9 ratio. Link to comment Share on other sites More sharing options...
edrach Posted July 28, 2012 Share Posted July 28, 2012 WoodsWagon said: Most probably not, but if it is it has a big silver sticker on the rear cover that will have LSD in big letters as well as the 3.9 ratio.Turbo LSD rear diffs for the EA82 were 3.700 ratio, not 3.900. Best test is as Bratman18 mentioned; jack up the rear end to get both wheels off the ground. Spin one wheel and watch the other; if the spins in the same direction is could be an LSD rear; if the other wheel spins opposite, it's an open diff. Only 3.900 rear LSD diffs were converted from an open diff and the clutch pack was installed from a turbo wagon. As far as I know SOA never made a 3.900 rear LSD for the EA82 models. Link to comment Share on other sites More sharing options...
natext6 Posted July 28, 2012 Share Posted July 28, 2012 I'm pretty sure I have a 3.9 LSD in my xt6, I'd have to double check tho. Link to comment Share on other sites More sharing options...
TomRhere Posted July 28, 2012 Share Posted July 28, 2012 natext6 said: I'm pretty sure I have a 3.9 LSD in my xt6, I'd have to double check tho. That was an option for the XT6, but they are as rare as hen's teeth to find one. Link to comment Share on other sites More sharing options...
WoodsWagon Posted July 28, 2012 Share Posted July 28, 2012 Yeah, I said 3.9 because it's an 85 5spd wagon. I'm assuming it's not LSD, so when he looks at the diff it will have a big silver sticker that says 3.9, and no LSD writing on it. So my mistake, I wasn't trying to imply it would have a 3.9 LSD in it. I have a 3.9 LSD, but that's because I swapped carriers. It could just as easily be a 4.11 or 4.44 if I used one of the other diffs out of my shed. Link to comment Share on other sites More sharing options...
superooo Posted July 1, 2016 Share Posted July 1, 2016 Umm, what if only 1 wheel and the driveshaft turn, either wheel will turn freely but only 1 turs at a time Link to comment Share on other sites More sharing options...
Caboobaroo Posted July 1, 2016 Share Posted July 1, 2016 It's open. If it's an LSD, both rear wheels will turn the same direction. Link to comment Share on other sites More sharing options...
superooo Posted July 2, 2016 Share Posted July 2, 2016 K thx, they had their crappy rim jackstand piined against the sticker, i knew i couldn't get that lucky Link to comment Share on other sites More sharing options...
wagonist Posted July 3, 2016 Share Posted July 3, 2016 Best bet is to put it in 4wd to check. Then if the other wheel turns the other way, it's definitely open. If you get resistance from turning, it's either an LSD, or it's stuffed... Link to comment Share on other sites More sharing options...
