turbosubarubrat Posted August 5, 2012 Share Posted August 5, 2012 u will need a cordless drill for the job probably, but if u have a angle corded that would work i know when i drilled out mine in my brat that i used my dads DeWalt 18v drill with a worn out nicd battery and it worked pritty good(my 1/2 corded black&decker hammer drill wouldn't fit:mad:sadly i used it so much i broke it a couple months later) but this time i used my craftsman c3 lithium 19.2v and it worked fantastic, i prefer corded so i know if u dont have a cordless but my craftsman gets alot done in a little time and its easier to handle Link to comment Share on other sites More sharing options...
natetheskate138 Posted July 18, 2014 Share Posted July 18, 2014 I have an 83 Brat with the same ignition as you. My key wouldn't turn so I dismantled the key end from the ignition switch end. It should be simple to pull apart. The ignition switch is the thing that has a few wires soldered to the back of it. The front of it has a rotating blue plastic piece with a T in it. In TurboSubaruBrat's last picture the very center horizontal nub thing is what fits inside the T to turn it to start the car. Then, like someone said above, you can use a screwdriver, sharpened popsicle stick, whatever to rotate the blue piece clockwise. I can't dismantle the right side(actual key side) of the switch but I'm going to try drilling out that pin tonight. I'll let everyone know how that goes. Link to comment Share on other sites More sharing options...
