Xadamx1 Posted August 3, 2012 Share Posted August 3, 2012 Okay well my 97 Outback legacy finally bit the dust a few weeks ago, got what looks like a control rod through the engine block. So I went out and bought a 99 Outback legacy same engine pretty much same everything except this one is a stick, fixed a few things on it and shes good to go. But today driving I noticed when under heavy acceleration in lower gears the window washer fluid sprays out the nozzle on the back window? Never seen this happen before any ideas what I could do to fix it? I have gone through half a gallon of washer fluid this week before I noticed the problem. Quote Link to comment Share on other sites More sharing options...
CoupedUpSubie Posted August 3, 2012 Share Posted August 3, 2012 Is it full power spray with the wiper going? I'm leaning towards a loose connection or some wires grounding out. Check the switch for the rear washer fluid. Quote Link to comment Share on other sites More sharing options...
Xadamx1 Posted August 3, 2012 Author Share Posted August 3, 2012 Is it full power spray with the wiper going? I'm leaning towards a loose connection or some wires grounding out. Check the switch for the rear washer fluid. No its not full power spray, it spray goes up maybe two inches from the nozzle, and no the wiper itself does not move. Quote Link to comment Share on other sites More sharing options...
brus brother Posted August 3, 2012 Share Posted August 3, 2012 (edited) This has been covered a few times. There is a check valve mentioned (I think Nissan) that you can install. Read the following thread and related links. http://www.ultimatesubaru.org/forum/showthread.php?t=22394&highlight=rear+washer+leak Edited August 3, 2012 by brus brother Quote Link to comment Share on other sites More sharing options...
Xadamx1 Posted August 3, 2012 Author Share Posted August 3, 2012 This has been covered a few times. There is a check valve mentioned (I think Nissan) that you can install. Read the following thread and related links.http://www.ultimatesubaru.org/forum/showthread.php?t=22394&highlight=rear+washer+leak You're right, sorry I didn't find it on the first search I did. Quote Link to comment Share on other sites More sharing options...
