ellets Posted August 4, 2012 Share Posted August 4, 2012 Some bad days are worse than others.To get out of my place and get to main road a steep hill must be climbed. Ie put in 4wd throttle up and hang on. No 4x4 forget it. I was headed out in GL coupe when I had a loud bang and car dove of the road. Pulling it out with larger 4x4 i see rt front wheel tucked up under fender and pointed hard right. A little more probing found that inner cv joint had exploded. There were little bits of it all over. everything is bent. Got a lot of parts to change. Good thing there is an old dl wagon up in the back As soon as weather permits will have to start pulling things off. Link to comment Share on other sites More sharing options...
maozebong Posted August 11, 2012 Share Posted August 11, 2012 damn, that is a bad day. hopefully its not going to be an expensive fix. edit: nothing on a L series subaru costs that much to fix i guess hopefully its a quick fix. Link to comment Share on other sites More sharing options...
