bstone Posted September 2, 2012 Author Share Posted September 2, 2012 Condenser is leaking! Thoughts? Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted September 2, 2012 Share Posted September 2, 2012 (edited) Condenser is leaking! Thoughts? Saw your condenser video. The leak looks like it is unrepairable, just because you can't get to the spot where it is leaking. You should be able to get a condenser pretty easily at your favorite wrecking yard. Shouldn't cost much. It is an easy swap out. If it were accessible, (and maybe it is if you tear off, or bend back some of the fins, that are in the way of the leak) you could seal the leak with JB Weld. I was able to do that once, and the JB held for years. I sold the car, JB is prolly still holding. The trick with JB, is to clean the surface really well, apply JB, and wait 24 hours for it to dry, before adding R134A. Edited September 2, 2012 by Rooster2 added more info Quote Link to comment Share on other sites More sharing options...
