Iokua Posted August 6, 2012 Share Posted August 6, 2012 Ok, so, I have an 87 RX and a shop replaced my distributor and they apparently had "a Subaru 1800 distributor out back" and put that in. Its been running...more or less now for about two years. I went to look into its misfire/stuttering problem further when i noticed the part number was 22100-AA440. Everything i find in reference to that number is a GL-10. I would like to know if its the right one, a new one says the part number would be one of these: 22100-AA450X, 72649003781 Is the random site i pulled those numbers from full of crap? are these distributors different at all? the full list of numbers is: 22100AA440 D4P86-03 A A703 do i have the right distributor? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 6, 2012 Share Posted August 6, 2012 All optical distributors are interchangeable. If it runs then it's the right one. /Thread. GD Quote Link to comment Share on other sites More sharing options...
gbianchi Posted August 7, 2012 Share Posted August 7, 2012 try swapping in a different coil, I had simular disty swapping going on and then solved the stumble with a coil, just 2cents, good luck...........G Quote Link to comment Share on other sites More sharing options...
