subi dude Posted August 8, 2012 Share Posted August 8, 2012 so i just got allthe new bearings in the hub...got the seals in. BUT...when i startputting everything back on the outer seal keeps popping out. and when i started tearing everything down, the outer bearing was the bad one. the seal wasnt even there from when ihad a shop do them. so what im asking is, what can i do to keep that bearing from slipping out, cause if i put everything back together. its jus going to slip out and im going to lose another seal and eventually a bearing .. PLEASE help... need to get done today Link to comment Share on other sites More sharing options...
subi dude Posted August 8, 2012 Author Share Posted August 8, 2012 NEvermind....just looks wrong Link to comment Share on other sites More sharing options...
Stubies Subie Posted August 10, 2012 Share Posted August 10, 2012 subi dude said: NEvermind....just looks wrong so, did you get the seal to stay put? Link to comment Share on other sites More sharing options...
subi dude Posted August 12, 2012 Author Share Posted August 12, 2012 Stubies Subie said: so, did you get the seal to stay put? yes, the shop that i had do the bearings JUST 2 MONTHS AGO, DIDNT even put the outer seals on either side!!! so im going to have to go talk to the shop and get some of my money back. cause that is just rediculous! how do you miss such a thing? Link to comment Share on other sites More sharing options...
Dee2 Posted August 12, 2012 Share Posted August 12, 2012 (edited) I'm trying to do my bearings, how did you get the strut separated from the knuckle ? I'm having no success after spreading the strut/knuckle compression slit, the strut is still locked in. Instructions only say: Separate knuckle from strut by pushing knuckle down. On Loyale, without damaging CV joint boot, carefully use a screwdriver to spread knuckle if necessary. DO NOT spread housing slit more than . 16"(4 mm). Remove upper strut retaining nuts. On all models, remove strut from vehicle. Bolts are out and simply spreading the knuckle compression slit apart isn't getting the job done Edited August 12, 2012 by Dee2 Link to comment Share on other sites More sharing options...
