foxrider295 Posted August 8, 2012 Share Posted August 8, 2012 Not sure if this is the right section to post this, but i just bought an 03 WRX and it needs a new turbo(its leaking), it is already set up for a bigger turbo, so i prolly wont get a stock one. What would you guys recomend for around $150-250? Ive never had a turboed car or anything so im new to this. Thanks Evan Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 8, 2012 Share Posted August 8, 2012 If it's setup for a larger turbo then you need to find out which one. You can't just slap a different one in and expect it to work with the cars tune. You need to get an exact replacement or have the car tuned for whichever one you settle on. That said - VF-39's are cheap these days. That's probably what I would look for. GD Quote Link to comment Share on other sites More sharing options...
wtdash Posted August 8, 2012 Share Posted August 8, 2012 Hi, As GD stated you need to match the turbo to what you have to ensure your tune still works. But for $150-200 you can't buy anything more than the original stock TD04 - over on NASIOC. VF39 and bigger are $300+. GL, TD Quote Link to comment Share on other sites More sharing options...
foxrider295 Posted August 8, 2012 Author Share Posted August 8, 2012 It has turbo pipes xs bov pink injectors. That's all that I know of as of now. (im finding out the rest soon) Would a t3t4 be a decent one? Quote Link to comment Share on other sites More sharing options...
bratman18 Posted August 8, 2012 Share Posted August 8, 2012 A t3 or t4 would not be bolt on. Sounds like you have a bunch of research to do. If you put on a different turbo than what was on there, or different than stock, you also need to have it tuned. There is really a fair amount involved with all of this, so make sure you learn as much as you can about your car, and what it had/has. Quote Link to comment Share on other sites More sharing options...
foxrider295 Posted August 11, 2012 Author Share Posted August 11, 2012 I've decided to go back to a stock turbo. Would a td04, td05, or td06 be sufficient? I found a new on on eBay for $230. Item number: 270641495133 Or this one 140610317349 Thanks. Quote Link to comment Share on other sites More sharing options...
bratman18 Posted August 11, 2012 Share Posted August 11, 2012 TD04 would be stock. You can find them for under $150 used, and if there is a new one for that little, it is most likely a cheap off brand that you don't want. Quote Link to comment Share on other sites More sharing options...
wtdash Posted August 11, 2012 Share Posted August 11, 2012 (edited) 1. Please clarify.. You stated: turbo pipes xs bov pink injectors Is that: - turbo -pipes (exhaust??) - XS BOV - Pink Injectors Pink injectors are probably STi 565cc injectors, from an JDM STi (Called JDM since they were only avl. on Japanese Domestic Models). Even though WRX and STi's are built in Japan, cars have different components depending on where they are being sold - Japan, Australia, Europe, USA, etc. _____________________________________________________________________________________________________________________________ 2.How do you know it's a bigger turbo? Better off to buy a USED lower mileage TD04 from NASIOC or Ebay. GET A REAL SUBARU turbo - not a 'knock-off' or you'll likely be buying another one in less than 10K miles. Guess how I know??? You MUST get a TD04 to be stock.You cannot just swap turbos and expect the car to run correctly,unless you use the exact same model of turbo that's currently installed. _____________________________________________________________________________________________________________________________ 3. Also, if you do have something bigger on there now, it's VERY likely you'll need to get your ECU re-tuned. In other words, your ECU/Computer is setup to run the leaking turbo you have now, and will not run correctly w/a TD04. Do you know what kind of tune is on the car? There are Cobb Accessport, Opensource, and other possibilities. And they'll all cost money to tune, unless you have the knowledge to learn how to use RomRaider and flash (tune) it yourself. Do you know the previous owner??? Where did you buy the car??? IF you knew who/what/where/how/etc it'll save you a LOT of grief figuring out the tune on the car. GL, Td Edited August 11, 2012 by wtdash Quote Link to comment Share on other sites More sharing options...
foxrider295 Posted August 11, 2012 Author Share Posted August 11, 2012 -Turbo XZ BOV -Pink Injectors -Silicone Turbo Hoses -APS Cold AIr Intake -Cobb 3in Exhaust This is a list of mods he gave me. he said its an original turbo, so its stock. I dont know what tune is on it. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 11, 2012 Share Posted August 11, 2012 Remove the BOV. They are silly and ignorant devices that only hurt performance. GD Quote Link to comment Share on other sites More sharing options...
bratman18 Posted August 11, 2012 Share Posted August 11, 2012 Replace the turbo with a stock one, possibly even replace the injectors with stock, as they might be too much for the small turbo, and then GET A TUNE! If it has a bad tune, or no tune at all with that aftermarket stuff, you are asking for your motor to die. Quote Link to comment Share on other sites More sharing options...
wtdash Posted August 12, 2012 Share Posted August 12, 2012 (edited) The car must have a tune to run the Pink injectors - 565cc vs 440cc stockers. I'd agree on getting another stock TD04 and run it....that's actually good news in that you don't need more tuning. IF it indeed has the stock turbo...... BUT I'm not sure why they'd put Pinks and Cobb exhaust w/out a bigger turbo??? Cobb 3" exhaust - Is that include a Cobb downpipe? There's the Turbo>>Downpipe>>Mid-pipe>>Axle-back>>Muffler. A 3" TBE (turbo-back exhaust) could include an aftermarket bell mouth downpipe (with or w/out catalytic converter). I'd guess it does have the Cobb DP (downpipe) based on the other mods..... Td Edited August 12, 2012 by wtdash Quote Link to comment Share on other sites More sharing options...
Durania Posted August 12, 2012 Share Posted August 12, 2012 Post some engine bay pictures, good ones, not from a cell phone. Quote Link to comment Share on other sites More sharing options...
