afterbang Posted August 10, 2012 Share Posted August 10, 2012 Hey everyone. A friend of mine attempted to put 2003 WRX wheels on a Volkswagen and the center hole was too small. He ground it would with a dremel tool about 1/16" in diameter bigger, squeezed them on, and then they ended up hitting the shocks. My sister-in-law is in desperate need of some wheels/tires on a budget for her 1993 legacy sedan and I was offered these wheels for $75.00. Cosmetically they are perfect but yeah, he ground them out on the back side. Would this cause a problem at all when installing them on the Legacy? I figure the bolt holes really keep them in place but I just want to make sure it won't be a safety issue. Thanks for your help. Quote Link to comment Share on other sites More sharing options...
NoahDL88 Posted August 10, 2012 Share Posted August 10, 2012 These wheels are hub centric, so it will effect balance, but if it feels fine I wouldn't worry about it. Quote Link to comment Share on other sites More sharing options...
forester2002s Posted August 11, 2012 Share Posted August 11, 2012 I have my snow-tires mounted on steel rims. The rims are supposedly for Subarus, but the centre hole is too large, so there is clearance to the hub. I have run these rims for about 10 years, without any problems whatsoever. PS I make sure to tighten the 5 wheel-nuts 'gently', alternating 1-3-5-2-4-1 etc., so as to make sure that the rim is centered correctly before the final torqueing-up. Quote Link to comment Share on other sites More sharing options...
Olnick Posted August 11, 2012 Share Posted August 11, 2012 You might want to consider "hub centric rings" to hold the wheels on center. I just googled it and came up with this for example: http://www.justforwheels.com/hub-centric-rings.jsp My wife's Maxima has them to position the alloy wheels and believe me, if one ring gets lost the car is virtually undrivable. (Ask me how I know. Just don't ask me why I ever went to Sam's Club for tires in the first place!) Quote Link to comment Share on other sites More sharing options...
afterbang Posted August 11, 2012 Author Share Posted August 11, 2012 Thanks guys for all the advice, awesome as usual. I couldn't pass these up for $75.00 so I'll just see how it works out. If there is any bounciness in the ride, I'll just take her car in to get the tires rebalanced. They are Les Schwab tires so it would be free anyways. I'll check out that centric rings if worse comes to worst. Still would be less than getting new steelies. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted August 11, 2012 Share Posted August 11, 2012 The biggest problem with the center being ground out is there is not a perfect machined center to balance the wheel. Those wheels will have to be balanced with a special lug adapter or they will be out of balance. Quote Link to comment Share on other sites More sharing options...
