subi dude Posted August 13, 2012 Share Posted August 13, 2012 So a while ago when i went wheelen through the trails and lots of puddles, it got dark by the time i left. I turned my headlights on, and whenever i would switch from high beams down to low beams, they would hesitate for about two-three seconds before turning on. This eventually got worse and started becoming five to seven seconds to turn on. And now tonight the low beams finally decided to not turn on at all anymore. Again, high beams work just fine, so im getting power. but my low beams are not working at all. I checked all the fuses for the heck of it, but i know thats not going to be it, otherwise they wouldnt work at all. So, what should i be looking at?? PLEASE help. i need to see without blinding everyone. Thanks, subi_dude Quote Link to comment Share on other sites More sharing options...
wentz912 Posted August 13, 2012 Share Posted August 13, 2012 Contacts in the switch are probably corroded/dirty. Take apart the column to get to the switch and clean it up. That's the first cheap/free thing I would try. Quote Link to comment Share on other sites More sharing options...
ivans imports Posted August 13, 2012 Share Posted August 13, 2012 headlight realys Quote Link to comment Share on other sites More sharing options...
subi dude Posted August 25, 2012 Author Share Posted August 25, 2012 headlight realys Where exactly are the headlight relays located??????!!!!!! And how do i check them? or do i just replace them without checking??? Thanks- subi_dude Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 25, 2012 Share Posted August 25, 2012 Under the dash - above the fuse panel. GD Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted August 25, 2012 Share Posted August 25, 2012 I Kindly suggest to do a Click on my Avatar, so you can reach a List of my Writeups in my "Public Profile" page, Scroll down to reach the one about "How to Swap Bosch Standard Relays instead of the Old Roundies" It is plenty of Pics & Explained Procedures about that, I Believe it could be Helpful for you. Kind Regards. Quote Link to comment Share on other sites More sharing options...
TomRhere Posted August 25, 2012 Share Posted August 25, 2012 When you remove the trim on the steering column to check the dimmer switch, check the connector for it also. Had the main feed in that connector gety hot and caused me to loose the low-beam lights. Brights worked, but not the lows. Quote Link to comment Share on other sites More sharing options...
subi dude Posted August 26, 2012 Author Share Posted August 26, 2012 When you remove the trim on the steering column to check the dimmer switch, check the connector for it also. Had the main feed in that connector gety hot and caused me to loose the low-beam lights. Brights worked, but not the lows. So if it was this connector or whatever it is that got hot on yours. What exactly do i do to replace or fix it? Quote Link to comment Share on other sites More sharing options...
Subruise Posted August 27, 2012 Share Posted August 27, 2012 if ya want, you can come over wednsday after i get off work, and we'll dig into it. i have extra relays and stuff too. Quote Link to comment Share on other sites More sharing options...
subi dude Posted August 27, 2012 Author Share Posted August 27, 2012 if ya want, you can come over wednsday after i get off work, and we'll dig into it. i have extra relays and stuff too. thats a possibility. where are you located? im in gig harbor/tacoma Quote Link to comment Share on other sites More sharing options...
TomRhere Posted August 27, 2012 Share Posted August 27, 2012 So if it was this connector or whatever it is that got hot on yours. What exactly do i do to replace or fix it? I cut the wires that were bad right near the connector and used some bullet connectors to make the connection. No futher issues. Quote Link to comment Share on other sites More sharing options...
Subruise Posted August 27, 2012 Share Posted August 27, 2012 you bought a dr 5speed from me, im over by 112th and waller rd remember? Quote Link to comment Share on other sites More sharing options...
subi dude Posted August 28, 2012 Author Share Posted August 28, 2012 you bought a dr 5speed from me, im over by 112th and waller rd remember? yea i remember. orry i keep forgetting your subruise. was that on river road? Quote Link to comment Share on other sites More sharing options...
Subruise Posted August 28, 2012 Share Posted August 28, 2012 text me tomorrow, ill give ya my address. im not by river road, im near 512. 253 tree oh juan seben fo oh too Quote Link to comment Share on other sites More sharing options...
