1-3-2-4 Posted August 15, 2012 Share Posted August 15, 2012 I happen to be looking under the car yesterday while getting ready to cut inside to remove the snapped transmission cross member bolt and I noticed one of those rubber assess panels are missing showing the primed unpainted inside of the car.. a little rust has started but what can I use to cover it back up with? Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted August 15, 2012 Author Share Posted August 15, 2012 Seeing how it has one on the drivers side the only way I can see how it was missing was when someone pulled it out thinking it was something else? I was thinking maybe using some thick window sealant or some RTV would do the trick? I have some precut cutting boards I can cut down to size and cover it.. it's thick enough for it. Quote Link to comment Share on other sites More sharing options...
ocei77 Posted August 15, 2012 Share Posted August 15, 2012 spray undercoating is what I would use. O. Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted August 15, 2012 Author Share Posted August 15, 2012 Is that something that's going to be hard to find? Quote Link to comment Share on other sites More sharing options...
brus brother Posted August 16, 2012 Share Posted August 16, 2012 Is that something that's going to be hard to find? http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_professional-grade-rubberized-undercoating-%2816-oz-%29-3m_7141477-p?searchTerm=spray+undercoating Autozone has the above 3M rubberized version that will be less likely to drip into your eyes. Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted August 17, 2012 Author Share Posted August 17, 2012 I tried looking for that stuff in autozone this morning I did not see it at all.. One also thing I did not notice is it can be used as sound deadening.. anyone try that before? I should check to see what the spray looks like I would like to see if it's worth putting inside on the floor under the carpet. Quote Link to comment Share on other sites More sharing options...
