Rpm90001 Posted August 15, 2012 Share Posted August 15, 2012 (edited) Can anyone give me a hand with getting a friends Subaru's fans working, ***He is currently driving from NY to Florida and is about 1/2 way there. ******He noticed his fans are not working. ***He does not ever remember them working, but checked them because he was running a little warm after 8-10 hrs of driving. He says the fans do not turn on with the air conditioning, and when the car was what he felt was getting very warm also no fan, I had him plug in the green plugs under the dash to see if they would turn cycle the fans on, ***and that also did not cycle the fans ***(I believe this will cycle the fans) I don't know what else to have him try other than swap relays. Any one have any suggestion on what to try while on the road? ******Common problems with the fan circuit? Best place to start to look while on the road. This may be an old or new problem...he never had an issue around town. 1998 legacy wagon 2.2 auto. Thanks for any help. George Edited August 15, 2012 by Rpm90001 Quote Link to comment Share on other sites More sharing options...
torxxx Posted August 15, 2012 Share Posted August 15, 2012 relays are under the hood in the main fuse box. Theres 2 fan fuses, a main fan relay and 1 ac fan relay IIRC. I would tell him to cut the wires to his fan and direct wire them for the rest of the drive. Driving down south, its not gonna hurt to overcool the engine. It will still be running above 165F coolant temp, but the thermostat will regulate the temp enough. When the thermostat is closed you arent circulating through the radiator, so its not gonna do any damage other than maybe wear the fans out faster. They are a 3 wire I think. Low speed High speed and ground. Hook them up backwards, fan spins backwards. I say run them both on high speed, you could tie the two fan wiring together (just make sure he leaves enough pigtail on the connector to splice it back to factory when he gets where he is ending his drive at) This is just a temp solution, I would suggest getting the fan issue solved once hes there. 15 feet of wire, 2 aligator clips and 4 butt connectors and hes back on the road Quote Link to comment Share on other sites More sharing options...
sosubeme Posted August 15, 2012 Share Posted August 15, 2012 Ran into this on a '93 Impreza, turned out to be the main fan fuse (20 amp?) at the fuse box inside the car on left side of driver footwell. If lucky he'll have a spare 20A still in it. Cheers! Quote Link to comment Share on other sites More sharing options...
Rpm90001 Posted August 15, 2012 Author Share Posted August 15, 2012 Thanks, he is watching this post from his phone. Quote Link to comment Share on other sites More sharing options...
CNY_Dave Posted August 15, 2012 Share Posted August 15, 2012 On my '03 the magic green connector does cycle the fans. Quote Link to comment Share on other sites More sharing options...
Rpm90001 Posted August 16, 2012 Author Share Posted August 16, 2012 Anyone know if it wile cycle the fans on the 98? Quote Link to comment Share on other sites More sharing options...
sosubeme Posted August 16, 2012 Share Posted August 16, 2012 The green connectors? They did on the '93 I mentioned earlier, AFTER the bad 20 amp main fan fuse was replaced with a good one. Anyone know if it wile cycle the fans on the 98? Quote Link to comment Share on other sites More sharing options...
