The FNG Posted August 19, 2012 Share Posted August 19, 2012 I drive about 30 miles a day on dirt roads and I noticed that after about a month of driving there was a ton of dust and dirt in my air filter box. It seems like the fender well is not the most ideal place to suck air, especially with large off road tires and a dusty road. I was wondering what would be the best alternative would be using the stock air box on a Loyale with SPFI. I have seen some crazy snorkels that go up to the roof and some sweet hot-air cone filters (not). I was thinking of some sort of snorkel that went out the fender and up to the windshield just to get out of the dust. I have searched a lot for pics and other ideas, but I really haven't come up with a lot. It seems like people talk about it a lot and never go through with it, picture links no longer work, or somebody convinces them it's a bad idea. I understand that too many turns or sharp turns or too much pipe can have negative side effects, but if I was to do a short snorkel of 3" pipe, how could that hurt air flow? Link to comment Share on other sites More sharing options...
ShawnW Posted August 19, 2012 Share Posted August 19, 2012 I seem to remember the noise being a factor. A couple of washable air filters (K&N) might be cheaper than all the tubing and such. Link to comment Share on other sites More sharing options...
bigjimd Posted August 20, 2012 Share Posted August 20, 2012 I've run K&N's and was really not happy with how many fines got through. Had em on both a Kawasaki Z1 and a dual Weber BMW 2002. Boy I miss both of those. And they lived on pavement. Maybe if you used the prefilter and cleaned em and reoiled every other week Link to comment Share on other sites More sharing options...
opus Posted August 21, 2012 Share Posted August 21, 2012 Speaking without thinking here. Could you make a kidney air filter work like we have on ea82 carb'd rigs? I hardly ever have to change air filters and I live on gravel roads. Link to comment Share on other sites More sharing options...
Idasho Posted August 21, 2012 Share Posted August 21, 2012 The exact reason I retrofitted the factory aircleaner onto my weber'd EA81 You wont find better filtration than a large paper element inside that aircleaner Link to comment Share on other sites More sharing options...
mikaleda Posted August 21, 2012 Share Posted August 21, 2012 my normal commute takes me through ten miles of dust and my experiance is the cars that get clogged less seem to be the ones that pull air from the front of the car Link to comment Share on other sites More sharing options...
djellum Posted August 21, 2012 Share Posted August 21, 2012 might be easiest to just unhook the plastic snorkel that goes into the fender and pull from the motor compartment. a trick people used to do was flip the top of the air cleaner so that its pulling from all sides instead of just through the hose. lots of air cleaners get bad in certain spots only. personally I would go for an air cleaner setup like the weber one. the stock box and hose might collect dust for later where the weber style will not let any settle around the element. Link to comment Share on other sites More sharing options...
The FNG Posted August 21, 2012 Author Share Posted August 21, 2012 My goal was to use the same air cleaner box and SPFI intake boot. I wanted to design a low cost tubing that just came up from the fender or something instead of replacing filters every oil change or more often. Link to comment Share on other sites More sharing options...
Txakura Posted August 24, 2012 Share Posted August 24, 2012 mikaleda has a point. I used to do 40 miles of gravel a day, 20 am, 20 pm... what if you ran a small diameter duct from the lower front side of the air filter box to behind the grill? lots of things in the way, yes but you could metal tape over the fender inlet, (easy to go back) and draw your air from the front of the car sounds like a hole saw and a trip to Ace hardware Link to comment Share on other sites More sharing options...
The FNG Posted August 24, 2012 Author Share Posted August 24, 2012 sounds like a good idea. maybe I read his original post wrong. Thanks! Link to comment Share on other sites More sharing options...
mikaleda Posted August 24, 2012 Share Posted August 24, 2012 another thing i have noticed is if someone is in front of me on a dirt road i back off until i'm not sucking dust that their car is kicking up. i have gone from changing my filters with my oil changes to changing them twice a year. just a thought. Link to comment Share on other sites More sharing options...
