Subieresurrect Posted August 22, 2012 Share Posted August 22, 2012 I need to replace my speedo and I am sick of not having a tach just wondering if anybody has ever taken one from a legacy and put it in a brighton and will that give CEL codes? Thanks for all your knowledge Sebastian Link to comment Share on other sites More sharing options...
WoodsWagon Posted August 26, 2012 Share Posted August 26, 2012 I usually put just the tach in, the blank plate comes out and the tach goes in with 3 screws when you disassemble the cluster. That way the odometer stays the same. You should be able to do a full cluster swap. As long as the plugs are the same on the back, subaru's pretty good about keeping pin functions the same. Link to comment Share on other sites More sharing options...
Subieresurrect Posted September 1, 2012 Author Share Posted September 1, 2012 Ok So I got one from a 1997 and the tach works great in there no problem. I compared the circuit ribbon at the back and they are the exact same. I however dont know if the speedo will work yet because my speed sensor is fried so thats my next step ohhh joy!!! Link to comment Share on other sites More sharing options...
