1999 subaru Legacy Brighton Dash Cluster can I replace with a Legacy and have a tach?
Subieresurrect
I usually put just the tach in, the blank plate comes out and the tach goes in with 3 screws when you disassemble the cluster. That way the odometer stays the same.
You should be able to do a full cluster swap. As long as the plugs are the same on the back, subaru's pretty good about keeping pin functions the same.
