Fuel Pressure Regulator Question
  Non Culpa said:
Hi Guys, Can anyone tell me if there is a standard Subaru Fuel Pressure Regulator that can adjust fuel pressure up to 45 psi? Regards Non Culpa:horse:
probably only adjust the stock one with some 'trick' like shimming or replacing a spring or something. Probably sealed up and not practical to alter. probably an aftermarket one is available set at a higher pressure - AEM, Megan Racing, etc.
um - what's wrong with the car?
Edited by 1 Lucky Texan
Nothing wrong with the car, just doing some modifications that require a 45 psi FPR. I have looked at aftermarket FPRs, just thought that there might be a Subaru FPR with higher psi than the one I have at the moment, it's only 36.3 psi.
ah - gotcha.
sry, dunno about STI or other FPR settings.
I have successfully "crushed" a stock FPR to increase the pressure. This basically pre-loads the internal spring. A couple blocks of wood and a vice, not hard. Do a little at a time and test it until you're at the pressure you want.
