*..Someone have a Carfax account?..*
Right front impact with another vehicle in May 2007, and the registration renewal for 2010 doesn't show up: it goes from 12/03/08, to 04/28/2009, to 12/29/2009 (???) to 04/21/2011. You may want to ask why.
After two major impacts my 06 impreza is yet to need an alignment
Where those frontal impacts? Did you (or the shop that did the repairs) check the alignment, if only to make sure it wasn't out of whack?
If the impact on the OP's baja was strong enough to bend the structure of the car then there should be an alignment report somewhere. If it wasn't strong enough, then it should not be a big deal at all.
In any case, I would go and check the car. Maybe the impact was not as bad...
