SuperBrat Posted August 26, 2012 Share Posted August 26, 2012 84 turbo coupe Link to comment Share on other sites More sharing options...
silverhelme Posted August 26, 2012 Share Posted August 26, 2012 Without going out and looking at mine ( it's only 40 degrees here ) it should be in the normal spot just in front of the the drivers side rear axle. Link to comment Share on other sites More sharing options...
Mykeys Toy Posted August 26, 2012 Share Posted August 26, 2012 I do not have a turbo car so it may be different but all of my gen 2 cars have always had them just in front of the rear passenger side wheel on a triangular plate held up by three 10 mm self tapping bolt/screws. Link to comment Share on other sites More sharing options...
SuperBrat Posted August 27, 2012 Author Share Posted August 27, 2012 not seeing it........... Link to comment Share on other sites More sharing options...
silverhelme Posted August 27, 2012 Share Posted August 27, 2012 (edited) Give me about 10 minutes and I will go out and look at mine. It's actually warm enough to go out this morning and look. Mykeys Toys is correct that the pump is on a plate in front of the passenger rear axle. I don't know why I thought it was drivers side I had to upgrade the pump on my Brat when I installed FI a couple of years ago and have changed several over the almost 30 years I've owned Subarus. Edited August 27, 2012 by silverhelme Link to comment Share on other sites More sharing options...
86 Wonder Wedge Posted August 27, 2012 Share Posted August 27, 2012 Right below the fuel filler door, infront of the rear tire. Its on top of a plate, you'll see hose in/hose out and an electrical connector. cant miss it Link to comment Share on other sites More sharing options...
SuperBrat Posted August 29, 2012 Author Share Posted August 29, 2012 Me and my flashlight arent seeing still, lots of hoses no visual pump, Link to comment Share on other sites More sharing options...
silverhelme Posted August 29, 2012 Share Posted August 29, 2012 Are you looking for the pump on a running ( or formally running ) car or one that you just picked up non running? If it is the latter it may have been removed, if the former you are just not looking hard enough. I can see mine through the wheel well on the triangle shaped plate in front of the passenger side rear axle even with the front corner of the wheel well. The only other possibility is someone pulled out the original and moved it elsewhere and in that case you will just have to follow the fuel line to find it. The only readily accessible places to put an aftermarket pump is in the original spot or in the engine compartment. Link to comment Share on other sites More sharing options...
SuperBrat Posted August 29, 2012 Author Share Posted August 29, 2012 The car ran fine, was running on empty, will run pouring gas in car, cant here fuel pump running no gas to new gas filter , thought id check out pump finding all the fuel lines from tank my eyeballs are not seeing pump Link to comment Share on other sites More sharing options...
Mykeys Toy Posted August 30, 2012 Share Posted August 30, 2012 I will try to get a pic for you this afternoon. Unless it has been replaced It will be right there.. I usually don't even jack the car up because I can reach under with everything I need. Link to comment Share on other sites More sharing options...
SuperBrat Posted August 30, 2012 Author Share Posted August 30, 2012 thanks, being a turbo and a car ahead of its time i was hoping it was not in the tank Link to comment Share on other sites More sharing options...
SuperBrat Posted September 2, 2012 Author Share Posted September 2, 2012 Well the new owner found the pump after 5 minutes of looking, near right center of car off driveline sitting flat on plate had to feel for it cause it was not visible Link to comment Share on other sites More sharing options...
Mykeys Toy Posted September 2, 2012 Share Posted September 2, 2012 I am glad you found it. I am sorry I didn't get to the pics I was going to take for you. Link to comment Share on other sites More sharing options...
