Loyale 2.7 Turbo Posted December 25, 2021 Author Share Posted December 25, 2021 On 8/26/2021 at 1:49 PM, Ionstorm66 said: So I have had terrible luck with any of the 4runner rear struts, they are still bending or blowing out. ... I think the issue is im bottoming out the struts while wheeling, as the stock bump stop is too short. ... The front springs/struts are amazing still, no issues there. Well, I'm glad that the Suspension mod worked fine for your Subie on the Front, but I really cannot understand the reason why your subie Can bottom those thick Toyota shock absorbers, installed in the Rear along the Honda coil springs for more load capability, I simply Can not understand. I bet there's something Wrong with your Subie's rear suspension, maybe with the U-joint... There are Many, Many other EA82 Subies running fine with the Suspension mods I described on the Writeup and no other one but you reported such a bottoming issue with that Strut combo... I hope that you'll find the issue and fix it as soon as possible. Kind Regards. Link to comment Share on other sites More sharing options...
Ionstorm66 Posted January 7, 2022 Share Posted January 7, 2022 On 12/24/2021 at 9:31 PM, Loyale 2.7 Turbo said: Well, I'm glad that the Suspension mod worked fine for your Subie on the Front, but I really cannot understand the reason why your subie Can bottom those thick Toyota shock absorbers, installed in the Rear along the Honda coil springs for more load capability, I simply Can not understand. I bet there's something Wrong with your Subie's rear suspension, maybe with the U-joint... There are Many, Many other EA82 Subies running fine with the Suspension mods I described on the Writeup and no other one but you reported such a bottoming issue with that Strut combo... I hope that you'll find the issue and fix it as soon as possible. Kind Regards. I definitely just need more spring. I threw some used 4runner springs on. It had almost no travel, but no bottoming out! So I need something between the 4runner and Honda springs. Link to comment Share on other sites More sharing options...
Ionstorm66 Posted April 9, 2022 Share Posted April 9, 2022 So I ended up finding some 4cylinder, 2wd, no ac 4running springs. They are perfect. I'm almost level front and rear, and have good travel. The combo of the new struts/springs front and rear is 2.5 inch's of lift with no spacers. Only issue is the rear springs a still a little stiff. The rear hopefully will settle a bit as it's about half inch higher than the front. Also if I lift a rear up, the front will pick a tire about an inch from the bump stop, so they are still a tiny bit too stiff. I am using the 4runner springs on pro comp 4runner struts. I had to drill out the stock upper spring mount to fit the new strut, and flip it upside down for the new spring. All of the spring Mount needed was a little notch to fit the upper strut mount. This is actually a good improvement because It gives you about two extra inches of spring length. 1 Link to comment Share on other sites More sharing options...
