need wire connector info, number, etc...
I have a 2003 Baja with a stock trailer wiring harness connector behind the rear passenger side wheel. I have a 2009 Legacy hitch wiring harness that I got really cheap, but the plugs don't match up. I want to modify the Legacy harness to fit the baja stock plug.
does anyone happen to know the manufacturer connector number for the baja side? the legacy plug layout is too different to modify it to fit.
both are 6 pin....
  • 1 year later...
Is the plug going to be inside the car? Could probably get a generic 6 pin connector at Radio shack, cut the factory plugs off.
If it doesn't need to be removed, just cut the plugs out entirely and solder the wires together.
