SubieTrav Posted August 30, 2012 Share Posted August 30, 2012 I put the rear body lifts from a 96 OB on my 92 Leg. I was about to put the fronts on but thought the bolts on the Leg wouldn't be long enough. Am I suppose to change the bolts too. How do I get them out of the of the Leg to get the longer OB bolts in. Link to comment Share on other sites More sharing options...
bratman18 Posted August 30, 2012 Share Posted August 30, 2012 There is a screw or bolt that holds them from the top. You should be able to see the plate for them on the top side of the frame rail on each side of the motor. And yes, you need to use the ones from the Outback. Link to comment Share on other sites More sharing options...
SubieTrav Posted August 31, 2012 Author Share Posted August 31, 2012 I went out and looked and saw the plate. I was thinking it was the same as the rears where the bolts went up into the frame. I'll have to go back to the junk yard tomorrow and get the bolts. Link to comment Share on other sites More sharing options...
