torxxx Posted September 12, 2012 Share Posted September 12, 2012 have you verified that your crank pulley didnt separate? Its a common issue on the EG33 engines because of the amount of HP. Nothing goes to say that an OB wont do the same thing. Powersteering puts the most load on the belt system, so if that pulley separated @ the center of it, its allowing the outer edge to slip and then regrab what little bit of edge is left where it separated. Take a paint marker or finger nail polish and put two marks on your crank pulley, then go drive it around the block and then shut it back off. The lines you painted should still be lined up. Quote Link to comment Share on other sites More sharing options...
ivans imports Posted September 13, 2012 Share Posted September 13, 2012 was making no noise at all just sliping on the ps pully not the alt was tight belt to just ribs were worn away enuff to slip under load try a belt just for fun Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted September 13, 2012 Share Posted September 13, 2012 ... ATF and power steering fluid are basically the same thing. Not exactly but Very Close... in fact, I switched over a decade ago from ATF to PSF (with Seal conditioners additive) on my age old EA82 due to a minor leakage and the leakage dissapeared and has gone for all these years; but the Steering becomes a Li'l Harder with PSF than with ATF. fixed mine yesterday the belt was slipping on the ribs of the ps pully but was tight the ribs of the belt were worn enuff that was not grabing when under load changed belt and problem was fixed ... I was about to suggest a Belt slip, usually those doesn't make Noise on the Power Steering pulley only. Why don't you try that? ... if the Belt is old, it could be good idea. Kind Regards. Quote Link to comment Share on other sites More sharing options...
presslab Posted September 14, 2012 Share Posted September 14, 2012 There is a small spool valve in the pump that regulates the pressure. Unlikely but it could be getting stuck. It's located just behind the high pressure outlet fitting. I modified mine to bump up the pressure as when I would get sideways the power steering couldn't keep up with my steering correction. Quote Link to comment Share on other sites More sharing options...
ericcroll Posted September 21, 2012 Author Share Posted September 21, 2012 Well, I changed the pump and the belt with no improvement, and have now discovered a wet spot on the rack. It looks like I'm going to have to change that sucker. UGH! I have heard that there is a thread detailing the process, but haven't been able to find it. I don't suppose one of you has a quick link? Quote Link to comment Share on other sites More sharing options...
ericcroll Posted November 19, 2012 Author Share Posted November 19, 2012 Well, I guess I procrastinated just long enough. I was about to do the job this past weekend, when out of nowhere, the problem went away. I'm thinking that maybe I had some air in the system that finally worked its way out, but I'm really just guessing. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted November 19, 2012 Share Posted November 19, 2012 Perhaps something was just gummed up and new fluid finally washed it away. Quote Link to comment Share on other sites More sharing options...
89Ru Posted November 20, 2012 Share Posted November 20, 2012 In case you still need it, here's a procedure for bleeding air from P/S from the overkill department, done on a '96 OBS. http://www.ultimatesubaru.org/forum/showthread.php?t=107972 Quote Link to comment Share on other sites More sharing options...
T'subaru Posted November 22, 2012 Share Posted November 22, 2012 Quote Link to comment Share on other sites More sharing options...
