torxxx Posted September 11, 2012 Share Posted September 11, 2012 Questions for you turbo hounds. I scored all the forced induction stuff off a 04 Baja turbo when I converted it to N/A for a customer. I refuse to build anything turbo so I gave the stuff to a buddy for his 91 SS. Questions are: What all needs to be modified to make the 2.5L turbo/interocooler work? It looks fairly bolt up to me, but I figured I'd ask anyways. As far as fuel management goes, the computer should compensate for the air to air being added. What if any are the differences between the EJ22T turbo and the EJ25 turbo? setting it in the car, it appears slightly bigger but it might just be my eyes playing with me. They are both TD04's correct? We also scored a 3.5" bellmouth downpipe off a buddies STi and we were thinking about using that. What effects are we gonna see on ODB 1 not seeing a cat there anymore? Thanks guys Link to comment Share on other sites More sharing options...
Turbone Posted September 11, 2012 Share Posted September 11, 2012 The turbo on the EJ22T is a VF11, quite small. I think the 2.5 is a TD05, but I'm not 100% sure of that. You might have to weld a bung on the DP for the O2 sensor, otherwise you will get a check engine light. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 11, 2012 Share Posted September 11, 2012 Computer won't care a bit about the missing cat. The Baja turbo will be a TD04 or TD05 or possibly a VF of some flavor....and is actually quite a bit larger than the '91 turbo - which is a VF11. They have radically different inlets so you will need a solution to get filtered, metered air into the turbo. You will have engine management issues for sure. It won't like how much air that turbo will flow and it will likely hit fuel cut due to the air volume passing the MAF. A stand-alone would be best since the OBD-I ECU is pretty dumb and will do really stupid things when you change up the airflow design. The intercooler will hit the AC hose and the clutch MC reservoir. GD Link to comment Share on other sites More sharing options...
WoodsWagon Posted September 11, 2012 Share Posted September 11, 2012 (edited) If you turn the boost up above 13psi you will need to build and install a fuel cut defender: http://www.surrealmirage.com/vrg3/fcd/ The biggest hurdle will be making a 90 degree inlet to the turbo. This is the best forum for info on EJ22t's: http://bbs.legacycentral.org/ Edited September 11, 2012 by WoodsWagon Link to comment Share on other sites More sharing options...
torxxx Posted September 11, 2012 Author Share Posted September 11, 2012 (edited) thx for the info on bbslegacy. I never knew about that site lol. Normally if I can't figure it out, and no one on USMB can I give up. I found a writeup on the TD05. I'll look tomorrow and see which turbo I have. The fuel cut defender doesnt look too hard to make, and I saw there is a few performance chips guys are running in the EJ22T modified stuff. Funny story about that EJ22T. We put a 4.44 4EAT in it, Outback lift blocks/struts and my buddy decided tonite that it SHOULD go anywhere my 98 OB with forester struts will. Hehehehe we'll just say he made it half way across the river crossing trying to follow me. Snapped my strap and chain trying to get him out. managed to get him back about 30 feet before I went and got my buddies mud truck to get him out. Once we got him on dry land, his passenger front wheel was locked up. Jammed full of gravel between the rim and caliper. Edited September 11, 2012 by torxxx Link to comment Share on other sites More sharing options...
