I have a oprutunity to get a SVX with a bad tranny, wonderin if it will bolt into a EJ car like a 2002 Impreza that has a 2.5?, I can get the whole car so I will have all the wiring, this is new to me tell me about this engine, is it a 2.2 just with more pistons? has anyone put one in a Imp? , is there any problems with that engine and setup? thanks guys
EG33 is a fantastic motor, capable of high mileages, very reliable, no big issues, and great power.
it's been stuffed into XT's, there's a few folks running EG33 swapped XT's on subaruxt.com, so they're quite familiar with installing them in other subaru's. two are members here but rarely post. they are regulars on subaruxt.com.
transmissions commonly fail, they need good ATF cooling. but that's a nonissue with a swap.
when the trans gos we put in 4.,44 ratios and a high stall from a 2.2 2wd and that kicks it in the pants the flex plate bolts up the same and wire harness could be cut down it would be very front heavy in a impreza is not a light motor and most of the weight is in front of axle would be a cool westfalia engine
There are quite a few of these swaps out there. I know a lot of you dont care for nasioc, but theres a wealth of info there if you know where to look.
http://forums.nasioc.com/forums/showthread.php?t=1652550&highlight=eg33+swap
http://forums.nasioc.com/forums/showthread.php?t=1323800&highlight=eg33+swap
http://forums.nasioc.com/forums/showthread.php?t=1209876&highlight=eg33+swap
Heres the link with all the threads...
http://forums.nasioc.com/forums/search.php?searchid=32820127
and yes scott, the TQ/flexplate etc will bolt up on the EG33. All it is, is basically 1.5x 2.2L's. Almost like they chopsawed a motor in have, took #3 and #4 cylinders and welded the cases together lol.
Keep me in the loop on your swap, I have a 91 SVX sitting in my driveway that I dont really want to drive anymore, I'd like to see it in my OB with your lift on it :P
An SVX in NICE shape is worth a bit of money, problem is the collector side of things, there is already a bunch of nice expensive ones out there. goto http://www.subaru-svx.net/forum/index.php and take a look around on there.
I own a early 92 SVX and I'm more tempted to yard out the EG33 and put it in my outback. #1, OB is a hell of a lot lighter than the SVX. #2 5 doors > 3 doors. #3 SVX parted out is worth more than it is sitting complete.
  • 5 weeks later...
  • 3 months later...
