Scott in Bellingham Posted September 12, 2012 Share Posted September 12, 2012 I have a oprutunity to get a SVX with a bad tranny, wonderin if it will bolt into a EJ car like a 2002 Impreza that has a 2.5?, I can get the whole car so I will have all the wiring, this is new to me tell me about this engine, is it a 2.2 just with more pistons? has anyone put one in a Imp? , is there any problems with that engine and setup? thanks guys Link to comment Share on other sites More sharing options...
zdriver123 Posted September 12, 2012 Share Posted September 12, 2012 Scott, you getting the 2 tone one in Sequim? Link to comment Share on other sites More sharing options...
nipper Posted September 12, 2012 Share Posted September 12, 2012 It will not fit without modification. The SVX 6 is a large long engine. Everything will bolt up, but you would have to relocate the radiator and supports i think. it is also a lot heavier. http://forums.nasioc.com/forums/showthread.php?t=148934 Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted September 12, 2012 Author Share Posted September 12, 2012 so will a EJ2.2 flywheel bolt up to it, as the SVX has a Automatic Link to comment Share on other sites More sharing options...
bluedotsnow Posted September 12, 2012 Share Posted September 12, 2012 I have read that the only sensible thing to do when an svx dumps its trans is to put a wrx 5 speed in it 10 secounds on google rendered this link http://www.smallcar.com/index.php?dispatch=products.view&product_id=29919 Link to comment Share on other sites More sharing options...
CoupedUpSubie Posted September 12, 2012 Share Posted September 12, 2012 It is possible. Here is an introduction video that has a ton of videos following it showing how to put one into a 96 Impreza wagon. http://www.youtube.com/watch?v=XfgSPvQ_7Ls&feature=plcp And yes it does run now. Link to comment Share on other sites More sharing options...
idosubaru Posted September 12, 2012 Share Posted September 12, 2012 EG33 is a fantastic motor, capable of high mileages, very reliable, no big issues, and great power. it's been stuffed into XT's, there's a few folks running EG33 swapped XT's on subaruxt.com, so they're quite familiar with installing them in other subaru's. two are members here but rarely post. they are regulars on subaruxt.com. transmissions commonly fail, they need good ATF cooling. but that's a nonissue with a swap. Link to comment Share on other sites More sharing options...
ivans imports Posted September 12, 2012 Share Posted September 12, 2012 when the trans gos we put in 4.,44 ratios and a high stall from a 2.2 2wd and that kicks it in the pants the flex plate bolts up the same and wire harness could be cut down it would be very front heavy in a impreza is not a light motor and most of the weight is in front of axle would be a cool westfalia engine Link to comment Share on other sites More sharing options...
Turbone Posted September 12, 2012 Share Posted September 12, 2012 There are quite a few of these swaps out there. I know a lot of you dont care for nasioc, but theres a wealth of info there if you know where to look. http://forums.nasioc.com/forums/showthread.php?t=1652550&highlight=eg33+swap http://forums.nasioc.com/forums/showthread.php?t=1323800&highlight=eg33+swap http://forums.nasioc.com/forums/showthread.php?t=1209876&highlight=eg33+swap Heres the link with all the threads... http://forums.nasioc.com/forums/search.php?searchid=32820127 Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted September 12, 2012 Author Share Posted September 12, 2012 thanks Guys Link to comment Share on other sites More sharing options...
torxxx Posted September 12, 2012 Share Posted September 12, 2012 and yes scott, the TQ/flexplate etc will bolt up on the EG33. All it is, is basically 1.5x 2.2L's. Almost like they chopsawed a motor in have, took #3 and #4 cylinders and welded the cases together lol. Keep me in the loop on your swap, I have a 91 SVX sitting in my driveway that I dont really want to drive anymore, I'd like to see it in my OB with your lift on it Link to comment Share on other sites More sharing options...
danbennett2u Posted September 13, 2012 Share Posted September 13, 2012 The SVX is a relatively rare and unique car. I would almost buy one up as an investment. Replace the trans, and garage the thing for another 20 years, is there any reason these cars wont go up in value and become collectible as they fall off the roads due to trans issues? Link to comment Share on other sites More sharing options...
torxxx Posted September 13, 2012 Share Posted September 13, 2012 An SVX in NICE shape is worth a bit of money, problem is the collector side of things, there is already a bunch of nice expensive ones out there. goto http://www.subaru-svx.net/forum/index.php and take a look around on there. I own a early 92 SVX and I'm more tempted to yard out the EG33 and put it in my outback. #1, OB is a hell of a lot lighter than the SVX. #2 5 doors > 3 doors. #3 SVX parted out is worth more than it is sitting complete. Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted October 13, 2012 Author Share Posted October 13, 2012 I got the e ngine home, need to get a detailed wiring harness drawing if anyone has alink Link to comment Share on other sites More sharing options...
bluedotsnow Posted October 14, 2012 Share Posted October 14, 2012 http://opposedforces.com/parts/ click click WINGO! Link to comment Share on other sites More sharing options...
Cyfun Posted January 15, 2013 Share Posted January 15, 2013 *bump* Any news on the SVX swap? I'm always curious about these. Link to comment Share on other sites More sharing options...
