soobie_newbie67 Posted September 13, 2012 Share Posted September 13, 2012 (edited) So, i picked up my 400 dollar legacy tonight. she started right up even after sitting since 2009, drove her home. 1 mechanical problem; CV axles. here's the other problems: Rear turn signals didnt work, found out lights were blown A/C heater fan doesnt come on radio shot none of the the gauges work, not even the odometer power windows dont work checking fuses tomorrow. too dark to do anything. Edited September 13, 2012 by soobie_newbie67 Quote Link to comment Share on other sites More sharing options...
Cougar Posted September 13, 2012 Share Posted September 13, 2012 It sounds like a fuse in the main panel under the hood is blown. Start your hunt there and verify power is passing through all the fuses there. If further testing is needed then move to the dash panel next and check those fuses. Quote Link to comment Share on other sites More sharing options...
soobie_newbie67 Posted September 14, 2012 Author Share Posted September 14, 2012 problems solved! i cant wait to drive this suby ^.^ everything works. 208000 miles and everything works, even the A/C! Power windows, power door locks, all works. only problem im having right now: tried to replace front CV axles; drivers side CV came out perfectly, passenger side CV; the splines have a death grip on the hub. have to replace the whole assembly. going to the junk yard tomorrow. Quote Link to comment Share on other sites More sharing options...
