Just a couple of odd questions.... noob questions
Any way to bring back the blue color ?
Do I need to replace the whole thing, I can't get the buttons to stay on.
How do I fix the bumper sag? Do I loosen it, then jack it up and tighten it back down.
Do these just come off with the screws on the top? Sand and spay?
Thanks for taking a look:headbang:
1. If you can peel a blue interior off of an identical car at the auto wreckers, then buy it and take it home and reinstall it on yours.
2. Add a slight touch of silicone on each clear button, to keep the over button.
3. 2 bolts on each side control the tilt of the front bumpers which can be readjusted.
4. The top rails are riveted in place. Forget about removing them. Paint with Hi-temp black instead.
you can use wd40 to re moisten the dry plastics. then treat with silicone spray. treat once a week until the color begins to stay. the color comes back until whatever you put on it evaporates. use an interior product that has uv protection. avoid armor-alls and stick with something silicone based.
