Resortx Posted September 18, 2012 Share Posted September 18, 2012 How many degrees should I cut the strut extensions at for an EA81 8" Lift? I have searched but all I can find is 8" EA82 Wagons. Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted September 18, 2012 Share Posted September 18, 2012 How many degrees should I cut the strut extensions at for an EA81 8" Lift?I have searched but all I can find is 8" EA82 Wagons. 14-15 degrees Quote Link to comment Share on other sites More sharing options...
Resortx Posted September 18, 2012 Author Share Posted September 18, 2012 So pretty much the same as for a 6" lift? Quote Link to comment Share on other sites More sharing options...
scoobiedubie Posted September 19, 2012 Share Posted September 19, 2012 Better put in a full body roll bar because it sounds like you are going to need it. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 19, 2012 Share Posted September 19, 2012 Strut angle to the body doesn't change no matter how much or how little lift you do. It's geometry and if you have a hard time with that please don't be building lifts and driving on the same roads as the rest of us. GD Quote Link to comment Share on other sites More sharing options...
Resortx Posted September 19, 2012 Author Share Posted September 19, 2012 Lol. It is geometry and there is a reason everyone cuts the strut extensions at 14-15 Degrees. I have seen pictures of wagons with bad camber problems. easier to ask then build one wrong and have to cut more steel. I am doing EA82 Control Arms and 10.5 31"s. As well as building a frame for it. I want it to be a big wagon. I have access to a full machine shop including a laser cutter. Already drew up the Diff drop plate and strut extension plates in draft site. and cutting everything this week. I want it to be a nice lift. So if there is anything you guys can help me with it would be much appreciated. Gotta learn somewhere right? Quote Link to comment Share on other sites More sharing options...
