lmdew Posted September 19, 2012 Share Posted September 19, 2012 Anyone seen any good 95 or 96 2.2 with EGR in the yards this last week? Anyone need a good core engine, DOHC 2.5 with a rod knock. Running 141K. Shoot me and email. Lmdew2@gmail.com Thanks, Larry Link to comment Share on other sites More sharing options...
Fairtax4me Posted September 19, 2012 Share Posted September 19, 2012 Wouldn't mind getting my hands on a 2.5 shortblock to rebuild in school but freightg would be $$$ from Co to Va. If you want the 95-96 engine for dual port heads, stick to 95. 96 they switched to single port. Otherwise, you can expand your search up to about 98-99. Besides the interference they fit/work greatly the same. If you want non-interference, go for any 90-95 and use your 2.5's sensors and intake manifold. Link to comment Share on other sites More sharing options...
WoodsWagon Posted September 19, 2012 Share Posted September 19, 2012 95 2.2l auto is the only complete bolt in with EGR. 96-98 2.2l auto needs the Y pipe to Cat flange swapped with it, but otherwise bolt in. 90-94's have no EGR port and a 2.5l manifold won't bolt up to them anyway. Link to comment Share on other sites More sharing options...
ShawnW Posted September 19, 2012 Share Posted September 19, 2012 Larry has done a bunch of these swaps. Ill watch but I haven't had time to hit a yard in weeks. Link to comment Share on other sites More sharing options...
WoodsWagon Posted September 19, 2012 Share Posted September 19, 2012 I think ABC Used Auto parts in Co Springs had one, but the intake manifold was off for some reason so I don't know if it had water in. They also had an integra GSR b18c with a seized cam. http://abcusedpartsco.com/ Call them and check. Link to comment Share on other sites More sharing options...
lmdew Posted September 23, 2012 Author Share Posted September 23, 2012 Found a 96 2.2 with 150K on it in the Den UPAP and thanks to Shawn I was able to install it and get it running. Runs great, typical HYD Lifter tick untill they pump back up. Thanks for the Y-Pipe Shawn. Link to comment Share on other sites More sharing options...
Terryduper Posted April 29, 2013 Share Posted April 29, 2013 You should check this online dealer http://www.hiperformer.com/automotive to get your engine or other parts as you need. You can check their inventory with listed different car model auto parts available there.You Link to comment Share on other sites More sharing options...
Terryduper Posted April 29, 2013 Share Posted April 29, 2013 (edited) Anyone seen any good 95 or 96 2.2 with EGR in the yards this last week? Anyone need a good core engine, DOHC 2.5 with a rod knock. Running 141K. Shoot me and email. Lmdew2@gmail.com Thanks, Larry Online deal are better Edited April 29, 2013 by Terryduper Link to comment Share on other sites More sharing options...
lmdew Posted April 29, 2013 Author Share Posted April 29, 2013 I have used www.car-part.com and purchased several used engines. By the time I figure in shipping they are in the 4-600 range. If I can get them at the UPAP they are $200. Rebuilts start at $1500 and go up from there. So you can see why I go used. Larry Link to comment Share on other sites More sharing options...
