fishboy Posted September 21, 2012 Share Posted September 21, 2012 A random question....apologies if I've posted this in the wrong forum section: Suppose I had a two-wheel drive car fitted with ordinary road tyres. Then on the very odd occasion I wanted to take this car off road and needed some decent grip. Rather than drive around with off-road tyres all the time that would be seldom used, is there any kind of product out there that could provide temporary traction in slippery/muddy conditions? I'm thinking something kind of like snow chains, but more suited to dirt/mud/gravel. Perhaps a kind of knobbly rubber skin that could be temporarily pulled over a tyre? Is there anything like that out there? The only other option I can think of would be to carry a spare pair of wheels in the boot already fitted with off-road tyres, but I'm trying to keep the weight down. Ideas? Link to comment Share on other sites More sharing options...
CoupedUpSubie Posted September 21, 2012 Share Posted September 21, 2012 Only thing that will hold up to the stresses of offroading is going to be an actual tire. That being said, anything that you put on your tires to aid in traction is subject to breaking. If you plan on going off the road then I would suggest a tire that has good reviews for both on the road and off. They are out there just not sure what the choices are for you in Australia. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted September 21, 2012 Share Posted September 21, 2012 (edited) although designed for snow/ice, something like these could help in an emergency if you're slow and careful; there are other brands of similar devices, maybe one made for dirt/mud? (they show this one off-road; ) and nothing would be lighter to carry than rope(make sure it will clear the caliper and dont' destroy your stems); Edited September 21, 2012 by 1 Lucky Texan 1 Link to comment Share on other sites More sharing options...
djellum Posted September 21, 2012 Share Posted September 21, 2012 you can get a good compressor to keep with you and just air them way down when you go off the pavement. then inflate again after you come back. find a tire that will run well on low psi and you should be able to greatly increase the traction by lowering the psi. I bought one for my brother for his birthday that you could set the psi you wanted and it would air down or inflate to it. added benefit of trail repair of flats Link to comment Share on other sites More sharing options...
fishboy Posted September 21, 2012 Author Share Posted September 21, 2012 Okay cool. Thanks for the suggestions guys. Might go down the track of some good on-road/off-road tyres and an air compressor. Link to comment Share on other sites More sharing options...
nipper Posted September 21, 2012 Share Posted September 21, 2012 I would just drop air pressure, and then be prepared to get yourself out if you get stuck.Also i would Since you are 2wd I would actually reconsider the spare set of tires depending upon what kind of wheelin we are talking about Link to comment Share on other sites More sharing options...
Idasho Posted September 22, 2012 Share Posted September 22, 2012 In nasty mud the best way to improve the grip of a road tire is chains. A FWD subaru + chains + flogging could get you places Link to comment Share on other sites More sharing options...
spazomatic Posted September 24, 2012 Share Posted September 24, 2012 Ive offroaded with tire chains in dry weather before. They're noisy and will rattle your teeth out if you go too fast, but they sure work well. I dont leave home without them. You never know when you'll need to get over an obstacle that your AT tires just cant handle Link to comment Share on other sites More sharing options...
tron Posted September 27, 2012 Share Posted September 27, 2012 Link to comment Share on other sites More sharing options...
AKghandi Posted September 30, 2012 Share Posted September 30, 2012 You could get 2 atv tires on stock 13"s and just switch the front wheels when you need to go offroading. Its a little more work but not too bad.. Link to comment Share on other sites More sharing options...
fishboy Posted October 1, 2012 Author Share Posted October 1, 2012 Great suggestions guys. Cheers! Link to comment Share on other sites More sharing options...
cider3200 Posted March 7, 2013 Share Posted March 7, 2013 for a brat with no lift what atv tire would you suggest for some thicker mud on the 13'' rims Link to comment Share on other sites More sharing options...
