wentz912 Posted October 16, 2012 Author Share Posted October 16, 2012 Thanks, will give that a try after I get the parts in that I received from ShawnW today! :headbang: It's on!!!:Flame: Link to comment Share on other sites More sharing options...
Fairtax4me Posted October 16, 2012 Share Posted October 16, 2012 Got the pass side pulley off, camshaft to pulley pin is gone and the hole the pin used to be in has been destroyed. Looks like it's time for a set of cams and another timing set! No progress on the no spin from the starter though. I'd inspect the cam journals and head bores VERY closely for wear. Possible the cam locked up and that's why it spun the pulley off. If the timing parts that were on the car don't appear to be that old it could just be somebodies goof after forgetting to tighten the cam pulley bolt. (seal change gone wrong) That cam can come out with the engine in the car, just have to remove the radiator. (easier said than done?) Link to comment Share on other sites More sharing options...
wentz912 Posted October 16, 2012 Author Share Posted October 16, 2012 I'd inspect the cam journals and head bores VERY closely for wear. Possible the cam locked up and that's why it spun the pulley off. If the timing parts that were on the car don't appear to be that old it could just be somebodies goof after forgetting to tighten the cam pulley bolt. (seal change gone wrong) That cam can come out with the engine in the car, just have to remove the radiator. (easier said than done?) Considering the belt looked pretty damn new when I got the timing covers off, and the cam bolt cam off without trying very hard with my standard length 3/8" ratchet, pretty sure it's just a goof. I understand that they will come out with the engine in the car. Still debating if I want to pull both and send the two good ones to delta for a quick re grind while I'm in Texas for a couple weeks... Link to comment Share on other sites More sharing options...
wentz912 Posted October 19, 2012 Author Share Posted October 19, 2012 (edited) So, a little update on this basket case of mine. Replace Cam. Done. Install new timing set. Done. Get starter to spin motor. Done. WHY YOU NO START, SUBARU!!!! Soo, taking the timing set apart 3 separate times in the thought process of "Oh, I must have just been a tooth off" No dice. Give GD a call to see if he has any tips for WTF is going on. Reminds me of the counting teeth method on the belt to ensure correct timing. Light bulb clicks so I try again. Get 'er buttoned up, turn the key, spins, but no start. :banghead::banghead:zzzzzzzzz: WTF?!?!?!?! At this point I'm about ready to start throwing things AND I'm losing a significant amount of light to work in. So I put my tools up and start poking around with my flashlight. Turn the crank by wrench until D-side cam pulley is where it should be. Crank and P-side pulley are also no where NEAR where they should be. Which means my belt jumped. A lot. WTF!!! So seriously guys, need some help here, either there is something wrong with my parts, or they were installed incorrectly. Feel free to treat me like an idiot at this point, because I sure feel like one. EDIT: Just read through the link concerning 2.2 timing belts here in the USRM. Seems I missed the step of pushing the tensioner back to the left after the belt is installed. Looks like I'll try that in the morning and see if i can get the damn thing to fire. Am also going to pour a few gallons of fresh gas in the old girl. No telling how old the stuff that's in her is. Edited October 19, 2012 by wentz912 Link to comment Share on other sites More sharing options...
Cougar Posted October 19, 2012 Share Posted October 19, 2012 I hope that is all it is. My fear is the valves on the left side are bent but hopefully that isn't correct. Link to comment Share on other sites More sharing options...
wentz912 Posted October 19, 2012 Author Share Posted October 19, 2012 I'm thinking I'm ok there. I can turn both cams by hand, albeit with a good amount of effort, but I can rotate both of them 360* and they require about the same amount of effort. Link to comment Share on other sites More sharing options...
wentz912 Posted October 19, 2012 Author Share Posted October 19, 2012 I'm thinking I'm ok there. I can turn both cams by hand, albeit with a good amount of effort, but I can rotate both of them 360* and they require about the same amount of effort. I'm just really not looking forward to having to tear EVERYTHING back apart again, compressing the hydraulic tensioner again in a very ghetto fashion, and trying all this again. BLEH Link to comment Share on other sites More sharing options...
wentz912 Posted October 20, 2012 Author Share Posted October 20, 2012 It runs! And quite well I might add. I was goofing the timing yesterday. Got her set all straight today and even got to drive it! Filled her up with premium in hopes that it will help the mid-throttle buck/hesitation its got going on. It threw a CEL at me just a couple blocks from my house, got them checked out and was found to be a misfire on cylinders 2&3. So, either they are isolated incidents, being on opposite banks and coils, or I just need new plugs and wires. Got the plugs and wires ordered today anyhow. Boy, these things sure do have a lot more pep than my old GL! In short: I is happy boy! :clap::clap::clap: Link to comment Share on other sites More sharing options...
wentz912 Posted October 20, 2012 Author Share Posted October 20, 2012 Well, put down about 110 miles in the old girl. Stumble/miss hasn't gone away yet. NGK wires are supposed to be here at 2. Hopefully that along with a new set of plugs will help cure the old girl. Seems to be running pig rich as well, filled it up yesterday and reset the trip meter. 110 miles later I'm reading at a measly 1/3 tank remaining! Leaving out of state for work tomorrow morning. Will have more time to work on it when I get back. Link to comment Share on other sites More sharing options...
porcupine73 Posted October 21, 2012 Share Posted October 21, 2012 You won't get away from the 'pig rich' running; that's just how they are, especially when cold. Subaru stated something like it was because they couldn't know what the vapor pressure of the fuel was, so basically they were going to run her nice and rich so that you could run with summer blend in winter conditions. Link to comment Share on other sites More sharing options...
wentz912 Posted October 21, 2012 Author Share Posted October 21, 2012 I meant richer than normal, seeing as how 3/4 tank has only gotten me 120 miles Link to comment Share on other sites More sharing options...
porcupine73 Posted October 21, 2012 Share Posted October 21, 2012 Well that doesn't necessarily mean she's running rich, she might just be running extremely inefficiently for any of a variety of reasons. The fuel gauges on these are notoriously inaccurate as sulfur builds up on the sensors too btw ... Link to comment Share on other sites More sharing options...
wentz912 Posted October 21, 2012 Author Share Posted October 21, 2012 Guess I'll have to see how much she takes when I fill her back up. And inefficient might as well equal rich to me since either way my fuel is disappearing and is requiring more of my RICHES to keep her full! :-p Link to comment Share on other sites More sharing options...
Fairtax4me Posted October 22, 2012 Share Posted October 22, 2012 Misfiring on 2 cylinders doesn't help fuel economy. You SURE you got that timing right? :-p Plugs/wires good place to start. hopefully that clears it up. If not it may be time for some strong fuel system cleaner and/or an O2 sensor. Link to comment Share on other sites More sharing options...
