edrach Posted October 6, 2012 Share Posted October 6, 2012 A few years ago you upgraded/fixed the a/c on my '84 blue brat. All I remember is your shop was in Bremerton. I can't remember your username, but I have a followup question for you if you remember me or the Brat. Link to comment Share on other sites More sharing options...
Scoobywagon Posted October 8, 2012 Share Posted October 8, 2012 That was me! Sorry, but I don't tend to be as active on here as I used to be. What's up? Link to comment Share on other sites More sharing options...
edrach Posted October 8, 2012 Author Share Posted October 8, 2012 Scoobywagon said: That was me! Sorry, but I don't tend to be as active on here as I used to be. What's up? Thanks for the reply; sorry for my faulty memory. It looks like I might need to top up the charge slightly. I never did find out what refrigerant you used on it and I want to make sure I add something that's compatible. I've got the gauges and know how to use them. We have Sureshot, Hotshot, R12 and R134a available. If I remember correctly you did use a blend after finding all the leaks in the system; just don't remember which one. I hope everything is okay with you; Regards, ---ed--- Link to comment Share on other sites More sharing options...
Scoobywagon Posted October 9, 2012 Share Posted October 9, 2012 Well, its been a while and I no longer work there. However, if I recall correctly, we used DuraCool for that. The problem is that it is a blend, so the lighter gasses boil off first. That means you really can't just "top it off". Same applies to all the refrigerant blends. You'd need to evacuate the system and recharge from scratch. Link to comment Share on other sites More sharing options...
edrach Posted October 9, 2012 Author Share Posted October 9, 2012 Scoobywagon said: Well, its been a while and I no longer work there. However, if I recall correctly, we used DuraCool for that. The problem is that it is a blend, so the lighter gasses boil off first. That means you really can't just "top it off". Same applies to all the refrigerant blends. You'd need to evacuate the system and recharge from scratch.Thanks, that's what I needed to know. Link to comment Share on other sites More sharing options...
