smotocon1 Posted April 2, 2004 Share Posted April 2, 2004 I just bought a 87 RX sedan with a auto tranny for $50 bucks. fixed the crank pully pin, replaced two coolant hoses and drove it home. the only problem is that when I put it in drive it will only drive in 1st gear. I have to manually shift it into 2nd. Is there some sort of adjustment that I can make to make it work? I'd love to drive 50mph someday. Any auto tranny help would be great. Link to comment Share on other sites More sharing options...
speedbump Posted April 2, 2004 Share Posted April 2, 2004 clean up the trans governor,easy fix and its in the USRM.Just did mine today, it took 20 minutes:banana: Link to comment Share on other sites More sharing options...
smotocon1 Posted April 2, 2004 Author Share Posted April 2, 2004 whats the USRM and what and were is the govening thingamajig. In other words Huh? Link to comment Share on other sites More sharing options...
speedbump Posted April 2, 2004 Share Posted April 2, 2004 look at the top of this page and click on www.ultimatesubaru.org and go into the trans section,you will find the write up there.Its sooooooo easy!and free.$50 for the car and no tranny to but and install,sweet! Link to comment Share on other sites More sharing options...
Meeky Moose Posted April 2, 2004 Share Posted April 2, 2004 also check the front diff to see if its got 80w90 in it, or ATF.. if its got atf in it, change it asap.. if the governor is apple cored real bad, then your tranny is toast.. are you sure its an RX? i don't recall an RX being made with an auto tranny.. Link to comment Share on other sites More sharing options...
calebz Posted April 2, 2004 Share Posted April 2, 2004 RX with an auto? I thought part of the deal with he RX.. especially 87+ was FT4WD D/R with difflock Link to comment Share on other sites More sharing options...
Meeky Moose Posted April 2, 2004 Share Posted April 2, 2004 methinks its a gl-10 turbo.. Link to comment Share on other sites More sharing options...
Adam N.D.J. Posted April 2, 2004 Share Posted April 2, 2004 Give us the VIN! Link to comment Share on other sites More sharing options...
smotocon1 Posted April 2, 2004 Author Share Posted April 2, 2004 your right it is a GL-10 turbo. Link to comment Share on other sites More sharing options...
speedbump Posted April 3, 2004 Share Posted April 3, 2004 didja try fixing it? Link to comment Share on other sites More sharing options...
