TheLoyale Posted October 9, 2012 Share Posted October 9, 2012 Can I swap my SPFI EA82 Coil on to my Carbed EA81? Is the SPFI coil any different than the Carbed coil? I am guessing the SPFI coil may be higher output, is this going to be an issue? Cheers, -Tom Link to comment Share on other sites More sharing options...
HATCHY Posted October 10, 2012 Share Posted October 10, 2012 ive used accel coil, and a msd blaster. both worked great. Link to comment Share on other sites More sharing options...
92LoyaleH4 Posted October 10, 2012 Share Posted October 10, 2012 (edited) Opps i misread the post...this is what i use on my EA82...i was gonna delete this post but i don't know how haha. I also used the Accel Coil with no problems!...looks cool too:brow: Also use NGK wires and Plugs and the BWD/Intermotor stuff for cap and rotor http://www.jegs.com/i/Accel/110/8140C/10002/-1 HATCHY said: ive used accel coil, and a msd blaster. both worked great. Edited October 10, 2012 by 92LoyaleH4 misread Link to comment Share on other sites More sharing options...
Petersubaru Posted October 10, 2012 Share Posted October 10, 2012 TheLoyale said: Can I swap my SPFI EA82 Coil on to my Carbed EA81? Is the SPFI coil any different than the Carbed coil? I am guessing the SPFI coil may be higher output, is this going to be an issue? Cheers, -Tom ..generally speaking, FI coils are different from the carb coils ..it will work in the beginning, but over time most likely will prematurely burn out the ignitor within the disy..ignition parts are designed as a system and are meant to work together as such.. Link to comment Share on other sites More sharing options...
TheLoyale Posted October 10, 2012 Author Share Posted October 10, 2012 Alright, well that won't be any good. I just dropped a new Disty into the EA81. I remember GD saying something about the MSD coils, as they are oil filled if I remember right, so you can not lay them on their side. I also remember him saying they will burn out the Regulator over time (Few years) Thanks for the replies, I just repainted the original coil/bracket for the restoration. Link to comment Share on other sites More sharing options...
