bushbasher Posted April 2, 2004 Share Posted April 2, 2004 I'm thinking about hard mounting my front diff from both points (no rubber bushing), would this create any problems? I've also got a pile of subaru driveshafts with no slip-yokes, and not enough Lada shaft parts to make drivelines. If I hard mount my diffs are slip-yokes necessary? The t-case mounts have rubber, and the tranny-to-t-case shaft still has the spline output on the tranny for some movement as well. On a side note, I was pulling the rear suspension out from under the car, and noticed that the tube part of the crossmember looked suspicious. So I tapped it with hammer and sure enough the undercoating flaked away to reveal swiss cheese Good thing I found that, I'm not sure how long that would have lasted under a lift and 30s. Its wierd how some parts are completely disintegrated on my car, and others are fine. I suppose it must be from salt damage. Link to comment Share on other sites More sharing options...
subarubrat Posted April 2, 2004 Share Posted April 2, 2004 I did a study of the IFS trucks in the parts yard and found that all but one of them had the front diff hard mounted. I chose a hard mount myself. I would not suggest relying on the splines to function as a slip joint, they aren't really designed to slip under load like the slip joint is. Given the chassis flex and driveline movement I would use a slip joint on each shaft for sure. I am picking up my shafts monday and I had them built from scratch other than the slip joints from the nissan shafts so that they would be true (very hard for a shop to do from a collection of parts) and have greasable U-joints stouter than stock. As for the tranny to Tcase shaft, no slip joint is used. Link to comment Share on other sites More sharing options...
Adam N.D.J. Posted April 2, 2004 Share Posted April 2, 2004 Another reason for the slip shafts is: how the heck ya gonna get a solid shaft in there? My rear diff and T-case are in rubber, but there is no way I could get the rear driveline in there if it was a solid unit. The flanges actually have a little recess to them that help hold them. Would be like trying to put in a rear axle without any slip in the DOJ's. Link to comment Share on other sites More sharing options...
