soobie_newbie67 Posted October 11, 2012 Share Posted October 11, 2012 I believe GD told me the ej22 is capable of taking 10 psi on stock internals, or was that a dream? There's a legacy (gen before mine) and I was wondering if it would be possible to grab the y pipe turbo and downpipe and swap them directly into my engine. And what would I have to go through to run the oil supply line and return line. Quote Link to comment Share on other sites More sharing options...
mellow65 Posted October 11, 2012 Share Posted October 11, 2012 I believe GD told me the ej22 is capable of taking 10 psi on stock internals, or was that a dream? There's a legacy (gen before mine) and I was wondering if it would be possible to grab the y pipe turbo and downpipe and swap them directly into my engine. And what would I have to go through to run the oil supply line and return line. not sure about what the guts can handle, but i can tell you the flaws in your swapping stuff. yes the y pipe will bolt up to the engine, but the cross member is different, the turbo cross member is notched for the pipe. the oil feed line is ran from a banjo bolt on the back of the passenger side head, not there on a NA motor. same goes with the oil return line, not there in a NA motor. sure all those things could be over come, but it probably would end up being cheaper and easier to just find a turbo car and have fun with that, or a turbo motor. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 11, 2012 Share Posted October 11, 2012 5 psi is max on an N/A unless it's tuned for E85. As noted - oil plumbing and exhaust fitment are just some of the issues you will run into - engine management, intake plumbing, and many other details which are not well documented in the communities are all hurdles to making it run correctly. It's not a simple task. GD Quote Link to comment Share on other sites More sharing options...
mellow65 Posted October 11, 2012 Share Posted October 11, 2012 have you ever seen a low boost NA motor? I'm wondering how it runs, I keep thinking a low boost turbo, normal compression set up on the mazdaru would be awesome. Quote Link to comment Share on other sites More sharing options...
soobie_newbie67 Posted October 11, 2012 Author Share Posted October 11, 2012 Alright. I think I'm gonna pitch the idea for now then and just wait till I order the legacy gt-b engine cause I will have to change the cross member for that too. No since in removing the engine twice. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 11, 2012 Share Posted October 11, 2012 have you ever seen a low boost NA motor? I'm wondering how it runs, I keep thinking a low boost turbo, normal compression set up on the mazdaru would be awesome. A "low boost NA" is technically refered to as a "high compression turbo". Yes I've seen quite a few of these - it's a popular build for race fuel or E85. Especially in the sand rail community. GD Quote Link to comment Share on other sites More sharing options...
