The Dude Posted October 13, 2012 Share Posted October 13, 2012 I called Crutchfield for a radio installation kit for my 2012 Impreza, I was told that one was not available. That's not good news, Crutchfield probably has off-the-shelf installation kits for thousands of different model cars. I removed the factory radio from the Impreza and it sure looked like a non-standard set up. Thin, strangely shaped stamped steel mounting brackets that attached the factory radio to unusual mounting points. Anyway, I "hacked' a Crutchfield installation kit for a 2009 Impreza. It kinda, sorta works. I ended gluing the covers and trim in with RTV. It's a not a real pretty installation, but it seems to be holding. The factory radio really wasn't all that bad, if it had had an USB port, or at least a front aux jack, I may have left in. Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted October 21, 2012 Share Posted October 21, 2012 Give it a little bit of time and they'll probably have a kit for it. Quote Link to comment Share on other sites More sharing options...
ShawnW Posted October 22, 2012 Share Posted October 22, 2012 It doesn't have the AUX in the center console? Pretty easy to add to most models with a dealer part. Quote Link to comment Share on other sites More sharing options...
O.C.D. Posted October 22, 2012 Share Posted October 22, 2012 (edited) If you are really bored here is my 2011 install for my WRX. I used a Scoshe kit without modification. http://forums.nasioc.com/forums/showthread.php?t=2237756 Damn I miss that car. Sad emoticon.... Edited October 22, 2012 by O.C.D. Quote Link to comment Share on other sites More sharing options...
