need help, tranny only moving forward
seems simple, but did you check the mechanical connections underneath? if they have come loose or off of the actual shift lever it wouldnt change gears no mater where its at.
oh okay, ill check the connection, maybe its loose as u said but its connected tho because i see when it moves
  • 2 weeks later...
