Broken belt, piston damage?
slap a set of 2.2 heads, cometic conversion gaskets, and intake onto it and frankie that beast!
Eh, not with a phase2. 2.2 heads don't flow as well, an they're only single port. I'd be much better off having my 2.5 heads decked if I wanted to go that route.
Thanks GD, that's what I though, but I wanted to ask just to be sure.
Use Phase I, pre-96 heads was I believe his suggestion. That's the typical "frankie" combination.
What's the engine going into? Then decide which Heads and Mani to use.
Again, that doesn't work well with phase2 land. You can't bolt a phase2 intake manifold to phase1 heads.
You can't bolt a phase1 intake to a phase2 head...
Anyway, the car sold out from under me. Though, armed with this info, I'm not worried to pick up a different car with a broken belt.
A phase one manifold works with a phase one head.
