bakerman1 Posted October 17, 2012 Share Posted October 17, 2012 Trying to figure out how to change out the bulbs in my fog lights. Can someone point me in the right direction maybe with pics? Thank you Ken Link to comment Share on other sites More sharing options...
J A Blazer Posted October 17, 2012 Share Posted October 17, 2012 Depending on rust and trauma you may or may not be able to remove the bulb from the back, but after 10 years I suspect that you will have to remove the entire assembly. It is held in place by two bolts which you approach from the front and which are directly above the fog light. There is a third fastener which you approach from below and behind, and which is one of those two-part press-fit plastic thingies. Link to comment Share on other sites More sharing options...
